FS: 737/2000 belize green Asheville nc REDUCED $5000 obo
Egalloway
Asheville nc
737/2000 for sale
PICTURE up in listing
737/2000
228xxx. on chassis
Engine:
Bogussvo new head for 800 hp running kelford 272 and adjustable cam gears
2.0 with 2g pistons
New ACL Race main and rod bearings
“New” crank from a bone stock 2.0 turbo car (probably had ~100k on it, but all dimensions in spec)
3g lifters
ARP head studs
All new gaskets
Exhaust:
New exhaust manifold studs
2g exhaust manifold
3” turbo back exhaust
Meagan Racing tubular O2 sensor housing
Meagan Racing 3” stainless downpipe
Meagan racing resonator
Dynomax muffler
no cat
Go fast/tuning:
AEM wideband O2 sensor
Ecm link on speed density
1000cc injectors
Gizzmo MS IBC electronic boost controller
Bullseye Power Borg Warner S256 turbo (~58 lb/min)
ETS Galant VR-4 specific intercooler
New Autometer boost gauge
4” intake with Amsoil air filter
Adjustable fuel pressure regulator
Electrical:
New Odyssey PC680 battery
New alternator
New oxygen sensor
New ignition coil pack
New ignition igniter
New NGK spark plug wires
New NGK BPR7ES spark plugs
New idle stop switch
New idle speed control motor
New throttle position sensor
New coolant temp sensor
Clutch/driveline/brakes:
Rebuilt clutch pedal assembly from Shep Racing
New Exedy clutch from Shep Racing
New clutch slave cylinder
Machined stock flywheel (done on a lathe so it's flat and step height is correct)
New flywheel and pressure plate bolts
4 bolt LSD
New passenger side CV boots
New front brake rotors & pads
New rear brake calipers
New e-brake cables
ABS delete with legit Galant GSX non-ABS proportioning valve & brake lines
Suspension:
New KYB GR2 shocks
New strut mounts
New KYB strut boots/bumpers
HR lowering springs
Lubricant/aesthetics:
Amsoil engine oil, filter & transmission oil
Redline rear diff oil
Carbon fiber hood and rear spoiler
3g headlights (I think)
Sunroof
Car has engine and trans out. The engine needs to be reinstalled with new built head and trans should be reworked to handle the power or it will blow up. Prior to head work car made 301hp 294tq from 4000 to 8000 held steady power nice and flat at 18lbs of boost on rough tune with speed density. Found out during/after dyno run it had 3 bad valves and needed head rebuilt. So off to dale bogussvo got a full tilt head.
I've got about 8 grand in it and I'd like REDUCED $5000 OBO
828-nine8nine-75five0 Eric I can text additional photos.
EHmotorsports
Beaverton
It would be beneficial to add the price in the title as well as make it more visible in your description. GLWS:)
Egalloway
Asheville nc
It keeps giving http 404 error when I try to post pictures. Any suggestions?
ktmrider
Tempe, AZ
^^ Pics are too big. Edit or retake below 2 meg.
Egalloway
Asheville nc
Still for sale. Lots of tire kickers and low ballers. Be a great car for someone.
turbophein
mass
installing the motor is the biggest cost for this car. why not install it? not worth $2500 as is IMO
JamesFoster
ALL
Personally I disagree turbophein. I would prefer a car with a freshly rebuilt engine, not yet installed, that way I can put it in and make sure the previous owner doesn't f*** it up.
turbophein
mass
kinda hard to f*** up a motor install?? what can go wrong? forgetting to put oil in, or antifreeze? tightening motor mounts /ubbthreads/images/graemlins/dunno.gif if you f*** up a motor install you do not belong owning these cars...period. building a motor, now that is completely different.
JamesFoster
ALL
It's not the install, it's the first startup, and first 100 miles of a new motor I worry about. Things like; if you have a heavy clutch, making sure you disconnect the clutch pedal switch before the first startup so there's no pressure on the crank for the first startup before oil has had a chance to run through the motor, and other little stuff like that. I know usually it doesn't make a difference, but that's just me.
Egalloway
Asheville nc
Not worth the effort on my end since it needs a trans built to handle the power of the motor, why put the motor in and still need a trans to handle it. Your opinion of price turbophein shows you want something for nothing, so does everyone else but I'm not giving it away. If I get more time I'll send the trans off and finish it as it is I won't.
Still for sale.
