Galant VR-4 Forums » Marketplace » Cars For Sale » UPDATED: FS: 1991 Belize Green Vr4 2.4L #1392 Bellevue, WA -- $4500 SOLD!
teamhightower
Crew Chief
Galant VR-4 org Post #: 1177856 posted 06/27/14 06:46 PM     Remind Me!  Send Private Message   Edit Post
****I have replaced the battery that was bad with a brand new one and I reset the ECU (the battery had glitched the ECU) and the car is now running again.****
For sale is my 1991 Mitsubishi Galant VR-4 (#1392/2000). These cars came to the U.S. in limited production in 1991 (2000) and 1992 (1000) and where the turbo sedans that proceeded the Mitsubishi Evoís. The VR-4 was the top of the line Galant and has a 2.0L turbo charged engine, AWD and all-wheel steering. The interior was leather and it includes options such as speed-sensitive wipers.
#1392 is a two owner car that started life in California. Iíve owned it since 2007. It has 193K miles, with the rebuild at 161K miles. This is a really fun car in very good condition. I had PINA Motorsports build me a 2.4L 4G64/4G63 hybrid motor for it as I really enjoy the torque these motors provide. Bottom end was built to handle over 400hp, but Iíve only built it up to 250ish. I never replaced the stock turbo and plumbing, but the car dynoíed at 203 wheel hp limited by the injector cycle. Best part is you have full boost very early (2200rpm) and that makes it very quick. The car came stock with big brakes and Iíve added a full Whiteline suspension in it. The interior is stock leather and is in reasonably good condition. Small wear spot on the drivers bolster and some of the stitching on the rear seats has popped. Should you want to upgrade the front seats to Evo seats, I have the custom made rails Iíll throw in. One trim piece along the driverís seatbelt track is broken, but I have a complete, color correct manual seatbelt replacement set that comes with the car. Stereo deck and speakers have been upgraded as well.
The bad:
ē Wear spot on the driverís seat and popped stitches on rear seat.
ē Broken interior trim piece along driverís seatbelt track (have manual seatbelt replacement set).
ē My son clipped a curb parking the car and knocked off the passenger side rear dogleg trim and scratched down the sideskirt. I have the trim and I believe with a little work it could be put back into reasonable shape.
The good:
ē Replaced the bad battery with a brand new one.
ē 2.4L motor has gobs of torque.
ē Body is in great shape with only minor scuffs and dings.
ē Good rubber (205/60/15 Goodyears two years old)
ē Custom Evo seat brackets included.
ē Color correct manual seatbelt replacement set included to replace the auto-magical stock belts.
Price is $4500 FIRM. No trades please.
I have too many other projects going on and this car isnít getting the attention it deserves. I havenít put the car up on Craigslist yet as Iím hoping a club member will scoop this up and enjoy it.
2007 Rebuild:
Bottom End
4G64 2.4L Stage I block
8.5:1 Ross pistons
Eagle Forged H Beam rods
Factory 100mm crankshaft
ACL main and rod bearings
ARP main studs
Main caps girdle plate
front case with new oil pump and balance shaft removal kit
poly motor mount
Top End
Stage I Street 4G63 twin-cam Head
Mild porting of intake and exhaust passages
3 angle valve job
ForcedPerfomance FPCam1 Camshafts (264/264)
ARP head studs
2.4L metal head gasket
Engine Management
DSMLink Engine Management
PLX DM100 OLED Display centered in dash cluster
PLX Wideband AFR Module
PLX Vac Boost Module
PLX Oil and Fuel Pressure Module
Fuel Delivery
Stock turbo, IC and fuel injectors
Walbro 255 fuel pump
Exhaust
Custom 2.5" steel exhaust with hi-flo cat and twin tip muffler
Transmission
Tranny rebuild, replaced all wearing parts
ACT2100 clutch
Suspension
KYB AGX Adjustable Struts
Whiteline urethane bushing set
Whiteline lowering springs
Whiteline front and rear swaybars with endlinks
Whiteline front strut brace
Body
Basic bodywork to remove door dings
Full spray in original Belize Green
**I have more photos upon request, and I can take any specific photos you may need as the car is in the driveway**
Email is the fastest way to reach me:
[email protected]
Edited by teamhightower (08/02/14 02:22 PM)
Posts: 77 | From: Bellevue, WA | Member Since: 09/03/07 | IP: (50.135.209.132) | Report this post to a Moderator
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1177863 posted 06/27/14 08:09 PM     Remind Me!  Send Private Message   Edit Post
Is this price for the car running and driving will or the price for it not drivable?
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2325 | From: USA | Member Since: 01/07/12 | IP: (71.177.218.188) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1177874 posted 06/27/14 09:08 PM     Remind Me!  Send Private Message   Edit Post
Damn, why couldn't this have been up for sale when I bought mine in December. I live in Renton.
Good luck with sale!
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (67.168.143.160) | Report this post to a Moderator
citymunky
Fake Title
733/2000
1505/2000
923/2000
832/2000
Galant VR-4 org Post #: 1177876 posted 06/27/14 09:18 PM     Remind Me!  Send Private Message   Edit Post
If I jump it, it runs. But when I shut it down there is zero charge in the battery.
Your battery is dead as knob, and will not hold a charge. When you jump it, your Galant is getting the amperage it need to spin the starter from the car's battery that the jumper cables are connected to, thus starting the Galant. The reason why it stays running after it was jumped is because the alternator is good.
Go find a used battery off craiglist for like $20 to $30 get the car running.
1990 MMC GVR-4
733/2000 (R.I.P. TurboRen) Sold.
1505/2000 (Loves strippers) Sold.
832/2000 (parts car) R.I.P.
923/2000 (my 1st) R.I.P.
Posts: 1749 | From: Chesapeake, VA | Member Since: 09/22/10 | IP: (108.26.83.105) | Report this post to a Moderator
teamhightower
Crew Chief
Galant VR-4 org Post #: 1178959 posted 07/03/14 07:32 PM     Remind Me!  Send Private Message   Edit Post
I thought the battery might be the case, I have been very busy (hence the lack of response on here) so I haven't checked the battery yet. Pending that the battery is the culprit, the price will be raised for the car running. Again, fastest way to reach me is via email.
Team Hightower
Posts: 77 | From: Bellevue, WA | Member Since: 09/03/07 | IP: (24.16.138.145) | Report this post to a Moderator
teamhightower
Crew Chief
Galant VR-4 org Post #: 1179042 posted 07/04/14 02:42 PM     Remind Me!  Send Private Message   Edit Post
I've updated the post with new information.
Team Hightower
teamhightower
Crew Chief
Galant VR-4 org Post #: 1182776 posted 08/02/14 02:26 PM     Remind Me!  Send Private Message   Edit Post
Thanks to Randy for flying out from St. Lou, Mo to pickup the car. Should be a fun drive home. 1392 is off on a new adventure...
Team Hightower
Wolfpuss
1392/2000
Galant VR-4 org Post #: 1184787 posted 08/16/14 11:30 PM     Remind Me!  Send Private Message   Edit Post
Thanks Greg! It was nice meeting you. My trip home was very interesting. Anyway, I plan on enjoying 1392 for a long time..
Posts: 156 | From: St Louis | Member Since: 07/08/14 | IP: (24.207.133.113) | Report this post to a Moderator
Generated in 0.049 seconds in which 0.017 seconds were spent on a total of 14 queries. Turbo powered.
