Clearancing a block to accept 100mm stroker crank
This is the first time I've done this, so feel free to add to or correct my info.
When you install an OEM or Eagle 100mm stroker crank the stroke is soo long that the rods will touch the block as well as the main caps. This is how you clearance/grind away the block to accept this extra stroke. SEE PICS
It has been discussed that doing this to the main caps MAY affect the rigidity of the bottom end. Some people use a support girdle(kigglyracing) to help remedy this. You should search/read and decide for yourself if you would like to use a main journal girdle.
Oil squirters are also a problem. With the longer stroke the piston comes down farther and can come in contact with the squirter tip. There are two ways of fixing this 1: carefully bend the oil squirter tips down. 2: Use evo8-9 oil squirters. Evo oil squirters are shapped in a way that requires no modification.
NOTE:If you're smart you should do the grinding before you take it to the machine shop because they clean it thoroughly. I didn't know this so I had to be carefull not to get shavings in the netheregions of my block. I used a shop vac to suck the shavings as I was grinding as well as a bunch of rags
So you draw a line from the center of the bore and out 3/4" each side(you'll end up with 1.5" to grind away)
shop vac sucking while I grind
The main caps are roughly 13mm thick. I shaved around 5-6mm off
i used evo 8 oil squirters and they still had to be bet out of the way. granted that modifying the evo one's was alot easier that tryin to modify the stock ones.
the problem i had was the piston skirt coming all the down and hitting the squirter. it only had to be bet slightly.
bazeng
Melbourne, Australia
I believe that the squirter clearance depends on the brand of pistons you use.
Wiseco's are meant to be the shortest skirt of the lot while JE / CP / Ross etc have longer skirts.
