Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » 4 bolt ?
4 bolt ?
silly4turbo
Galant VR-4 org Post #: 284859 posted 12/13/05 11:09 AM     Remind Me!  Send Private Message   Edit Post
I've got a 4bolt rear..and latley I've been noticing that between gears and if I'm not smooth on the clutch, the rear seems to have some slack in it or something and it'll make a slight sound and almost like a "thud" sound..it dosen't sound harsh, but I don't think it's should be doing this ? any idea's ? I read somewhere about shimming the rear..but not sure.. I also get it sometimes when I abruplty let off the gas. I'd just liek an idea od what could be causing this, most likely it could be anumber of different thing..
Edited by silly4turbo (12/13/05 11:11 AM)
| | | IP: (129.44.165.2) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 284864 posted 12/13/05 11:20 AM     Remind Me!  Send Private Message   Edit Post
My stock rear end is starting to do this
The rear probably needs to be rebuilt. I havn't inspected the driveshaft joints yet tho.
1992 Nile black w/sunroof
Posts: 5764 | From: Lafayette, IN | Member Since: 08/06/02 | IP: (68.57.212.169) | Report this post to a Moderator
Josh Weaver
Galant VR-4 org Post #: 284874 posted 12/13/05 11:55 AM     Remind Me!  Send Private Message   Edit Post
Yeah, either your rear end is due for a rebuild or your drifeshaft u-joints are loose. Inspect your driveshaft if you can.
-Josh
| | | IP: (64.253.43.242) | Report this post to a Moderator
mj_rosenfeld
Galant VR-4 org Post #: 284875 posted 12/13/05 11:57 AM     Remind Me!  Send Private Message   Edit Post
Could also be a loose/broken/missing bolt that holds the diff in place.
Mike R.
| | | IP: (64.0.248.227) | Report this post to a Moderator
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 284881 posted 12/13/05 12:23 PM     Remind Me!  Send Private Message   Edit Post
I replaced all of the spider joints and carrier bearings on my drive shaft and still have "looseness and noise" in the rear. I am pulling the rear next week and rebuilding it. New shims, seals and bearings. I am hoping that will fix it. As you have noted, it is the most noticeable when getting on and off the throttle.
Scott
525
Posts: 2054 | From: Norwell, MA | Member Since: 07/24/04 | IP: (66.30.151.127) | Report this post to a Moderator
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 284967 posted 12/13/05 05:58 PM     Remind Me!  Send Private Message   Edit Post
Just in case you want to rebuild your rear diff. here are the parts you need. They are all available from the dealership or parts vendors.
MR305708 4 pcs.
MR305709 1
MB569528 1
MD707184 2
MB393929 1
MB393955 1
MB393956 1
MB393957 2
MB185360 1
MB185350 1
MB241903 1
That will get you all of the seals, bearings and shim kits. It should come to about $200 for the parts.
silly4turbo
Galant VR-4 org Post #: 285064 posted 12/13/05 11:23 PM     Remind Me!  Send Private Message   Edit Post
nice, thanks for the parts numbers powerplay !
thanks for all the replies, powerplay, let
me know how the rebuild goes
| | | IP: (65.78.24.206) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 285126 posted 12/14/05 08:34 AM     Remind Me!  Send Private Message   Edit Post
what did you spend? can someone get a CAPS pic of the rear end up?
Posts: 2359 | From: Key West | Member Since: 12/25/03 | IP: (24.154.184.10) | Report this post to a Moderator
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 848966 posted 11/11/09 07:27 PM     Remind Me!  Send Private Message   Edit Post
I was asked for additional information on this subject so hopefully this helps. These were the prices I paid at the time from the dealer.
MR305708 4 pcs. Washer $5.92
MR305709 1 pcs. Washer Set Viscous $3.95
MB569528 1 pcs. Shim, Viscous $5.12
MD707184 2 pcs. Oil Seal $6.45
MB393929 1 pcs. Oil Seal $6.35
MB393955 1 pcs. Bearing $21.45
MB393956 1 pcs. Bearing $22.87
MB393957 2 pcs. Bearing $22.03
MB185360 1 pcs. Shim Set $21.92
MB185350 1 pcs. Shim Set $20.71
MB241903 1 pcs. Spacer Set $6.92
Total: $189.94
Scott
525
Posts: 2054 | From: Norwell, MA | Member Since: 07/24/04 | IP: (65.96.227.171) | Report this post to a Moderator
Jesh
Member +
898/1000
Galant VR-4 org Post #: 870938 posted 02/04/10 12:16 AM     Remind Me!  Send Private Message   Edit Post
i also have this problem when i had a 3 bolt rear and then i did the 4 bolt swap. the problem didn't go away, all my driveshaft u-joints are tight. i believe my transfer case has slop in it. not saying this is your problem, but just something else to consider. it would be easy to check and could save you some headache:)
'92 Galant VR4 898/1000
'91 Galant GSX - parts
'93 Laser RS - gone
Posts: 281 | From: Soldotna, Alaska | Member Since: 11/12/09 | IP: (24.237.254.185) | Report this post to a Moderator
Generated in 0.038 seconds in which 0.017 seconds were spent on a total of 14 queries. Turbo powered.
