1) ABS computer in the trunk (near antenna)
2) ABS sensor under center console (near the shifter)
3) ABS unit under the hood
4) ABS wheel sensors
5) Pull the fuses from the engine bay (Thanks, Hertz)
6) There's also a relay on the driver's side behind the panel below the hood release (thanks, dsmsleeper)
<will add more as mentioned>
Making a list of things I plan on pulling out...
Things I will need:
1)Actually, 92 AWD DSM's came with the smaller brakes. You'll need the 93-94 AWD, non-ABS valve.
(thanks, Jon - JoeC)
2)The Galant GSX front brake lines work perfectly under the hood. The rear ones do not need to be changed. You will not be able to find these new so you will have to find them in a yard.(Thanks, Jon)
Lets keep this post simple, no big discussions on proportioning valves and if ABS is good or bad, yadda yadda yadda. This is for archiving purposes.
There is some sort of sensor on the left corner of the trunk..is this ABS or fuel related? Not quite sure what this thing is...
Thanks!
