Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Oxygen sensor replacement
cevic
Galant VR-4 org Post #: 109589 posted 09/12/03 11:10 PM     Remind Me!  Send Private Message   Edit Post
I was trying to replace the o2 sensor in my galant. However, I couldn't remove the old one from the exhaust. It's too deep to reach and I have no idea what kind of tool should I use. Any suggestions?
| | | IP: (24.124.42.112) | Report this post to a Moderator
PRE-EVO
Galant VR-4 org Post #: 109590 posted 09/12/03 11:20 PM     Remind Me!  Send Private Message   Edit Post
A crows foot or an oxygen sensor tool (similar to a crows foot but with a deeper socket type look). Oh and make sure you use some penetrant first to loosen it up some to make it easier to remove.
| | | IP: (68.7.156.179) | Report this post to a Moderator
Dan D
220, 221... whatever it takes
410/2000
Galant VR-4 org Post #: 109591 posted 09/12/03 11:44 PM     Remind Me!  Send Private Message   Edit Post
An extension?
Posts: 1158 | From: Brownsburg, IN | Member Since: 02/27/01 | IP: (208.251.251.8) | Report this post to a Moderator
4orced4door Galant VR4.org Moderator
Out Standing
Galant VR-4 org Post #: 109592 posted 09/13/03 12:08 AM     Remind Me!  Send Private Message   Edit Post
Even with the right tool mine rounded off. Doh! Now I'm waiting for my new o2 housing from Andy so I can replace the whole mess.
Posts: 9846 | From: Raleigh, NC | Member Since: 07/19/02 | IP: (65.33.242.24) | Report this post to a Moderator
Tangent
Galant VR-4 org Post #: 109593 posted 09/13/03 12:09 AM     Remind Me!  Send Private Message   Edit Post
I am trying to replace my oxygen sensor right now what a pain in the ass. I have used penetrant the o2 deep socket and a nice 12 inch extention. Still no luck.
When you buy the o2 socket see if you can find a 22mm one. The one I have is a POS universal 7/8" and 22mm socket. The problem is that 7/8" is equivalent to 22.225mm not 22mm, so it has begun to strip the bolt corners. You may want to cut the wires and use an exact 22mm six point deep socket to get the old one out. Twelve point sockets suck. That is what I am going to try tommorrow.
| | | IP: (4.63.90.75) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 109594 posted 09/13/03 02:03 AM     Remind Me!  Send Private Message   Edit Post
It also helps sometimes to have the car warmed up.
PB blaster is also my choice of lubricants. Much better IMO than WD-40.
Posts: 382 | From: Noblesville, Indiana | Member Since: 08/18/01 | IP: (68.51.71.91) | Report this post to a Moderator
ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 109595 posted 09/13/03 08:11 AM     Remind Me!  Send Private Message   Edit Post
GTFFT! cost is about 30 bucks, fits perfect, pops that sucker right off. dont use the universal kd tools slotted sensor crap, it MUST be a closed 6 point. like he said, the only other option is to cut the wire, and use a deep socket, like an impact, and a huge breaker bar. dont forget to never sieze the crap out of the new one, it will have some on it, but more is ok. and use NICKEL based, all others will act like a threadLOCKER.
Posts: 7529 | From: krum texas | Member Since: 02/23/01 | IP: (4.47.42.108) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 109596 posted 09/13/03 03:28 PM     Remind Me!  Send Private Message   Edit Post
Took me about 2 months to get mine off, and I had to get Ken (Hibern8) to actually bust it loose. [Smile] I supplied him with a 5 foot length of pipe as a bar, seemed to do the trick.
About 12 applications of WD-40, dozens of muscle-straining attempts (without enough leverage) didn't do it. Leverage makes the biggest difference, and I would agree, WD-40 is not as effective as PB Blaster or Liquid Wrench, but it is better than nothing.
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (67.162.74.189) | Report this post to a Moderator
crucible
Galant VR-4 org Post #: 109597 posted 09/13/03 03:29 PM     Remind Me!  Send Private Message   Edit Post
I had to actually stand inside the engine bay with my foot on the breaker bar .After a few buckets of cuss it finally snapped.I broke 2 extensions with this method.It was the biggest fuck job Ive had to do so far
Cruce
| | | IP: (67.87.126.26) | Report this post to a Moderator
ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 109598 posted 09/13/03 05:10 PM     Remind Me!  Send Private Message   Edit Post
i just now took mine off. factory tool, 27mm box wrench, one yank, and i got it. hope the downpipe goes on as easy.
Posts: 7529 | From: krum texas | Member Since: 02/23/01 | IP: (209.220.6.232) | Report this post to a Moderator
Alex Morales
Galant VR-4 org Post #: 109599 posted 09/14/03 01:26 AM     Remind Me!  Send Private Message   Edit Post
I just changed my O2 sensor about a week ago. I started to round it off cause it was so tight so I tool some MAF gas and toasted the shit out of it. I waited till it was cherry red and through the O2 Socket on it. The thing spun right off.
**Fire it up baby**
Alex.
| | | IP: (67.193.167.40) | Report this post to a Moderator
gtluke
Fegbasket
Galant VR-4 org Post #: 109600 posted 09/14/03 01:40 AM     Remind Me!  Send Private Message   Edit Post
ha wd-40 is garbage.
i use this stuff called "lube job" (ha right?)
it works incredible, and the cans last FOREVER. it sprays nice too... and its cheap. some woman just calls me at my work and asks how much more i need, otherwise i'd tell you guys how to get it [Smile]
i think i've been though less than a case of it (12 cans) in about 3 years. i'm telling you these cans last forever. and i'm a professional mechanic
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (141.153.206.160) | Report this post to a Moderator
Out Standing
Galant VR-4 org Post #: 109601 posted 09/14/03 01:42 AM     Remind Me!  Send Private Message   Edit Post
Or you can do it the easy way and put a new o2 sensor in a new o2 housing. [Wink]
Posts: 9846 | From: Raleigh, NC | Member Since: 07/19/02 | IP: (12.92.27.75) | Report this post to a Moderator
BiggiB42
Galant VR-4 org Post #: 109602 posted 09/15/03 01:20 AM     Remind Me!  Send Private Message   Edit Post
just borrow the o2 socket from autozone
| | | IP: (152.163.252.33) | Report this post to a Moderator
broke down
See my Member?
1725/2000
Galant VR-4 org Post #: 109603 posted 09/15/03 01:23 PM     Remind Me!  Send Private Message   Edit Post
IMO, PB blaster is the ONLY rust penetrant to use soak it every day for a while. Also, try heat. A propane or MAPP gas cylinder should help. MAPP gas gets way hotter than propane, and since the o2 housing and sensor are used to extreme heat, they shouldn't get damaged from the heat. Get it red hot, then try.
Posts: 1075 | From: Muncie, Indiana | Member Since: 07/15/02 | IP: (66.208.229.5) | Report this post to a Moderator
BiggiB42
Galant VR-4 org Post #: 109604 posted 09/15/03 02:25 PM     Remind Me!  Send Private Message   Edit Post
ok i got my o2 sensor off no problem but the little f%^*er wont bite on the o2 housing. help. i have to go to work in an hour
TOF
Galant VR-4 org Post #: 109605 posted 09/16/03 12:14 PM     Remind Me!  Send Private Message   Edit Post
If you are removing a bad o2 sensor you can just break it so you can get a socket on it. Use a 6-point socket to avoid rounding. Presoaking with deep creep or PB Blaster helps.
I replaced mine when I changed the O2 housing. The problem wasn't a bad sensor. But the thread lands were messed up so that the sensor wouldn't seat into the new housing. I probably could have gotten it on eventually but I didn't want to mess up the threads on the housing in the process.
BiggiB42... this may be the problem you are having. Check the condition of the threads on the sensor and on the housing.
| | | IP: (139.177.224.71) | Report this post to a Moderator
BiggiB42
Galant VR-4 org Post #: 109606 posted 09/17/03 11:22 PM     Remind Me!  Send Private Message   Edit Post
i managed to get the sensor on i just was having trouble with the angle i was putting it in
MidEngine210
Galant VR-4 org Post #: 109607 posted 10/25/03 07:07 PM     Remind Me!  Send Private Message   Edit Post
quote:
Do you have the part number for the factory tool?
| | | IP: (64.63.204.20) | Report this post to a Moderator
MidEngine210
Galant VR-4 org Post #: 109608 posted 10/25/03 07:19 PM     Remind Me!  Send Private Message   Edit Post
Also, where can I check the o2 sensor heater ground (I think that's what it is called)? I tried removing the sensor today with no success, but I plan on using another o2 socket soon. Any help is appreciated.
77/2000
Galant VR-4 org Post #: 109609 posted 10/27/03 10:16 PM     Remind Me!  Send Private Message   Edit Post
Check for broken wires, especially at the connector (both sides). My heater ground wire is broken (I know it's the heater ground because my O2 sensor works, but when it cools off, the sensor slows down considerably and the car will bog at idle).
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (67.165.155.101) | Report this post to a Moderator
0 registered and 0 anonymous users are browsing this forum.
Generated in 0.086 seconds in which 0.039 seconds were spent on a total of 14 queries. Turbo powered.
