· Evo III Big 16 Turbo · Evo III Manifold and O2 housing · Evo VIII Injectors 255 fuel pump · Rebuilt Head new gaskets studs etc. · Valve job new guides pressure test & resurface · New Non-Ticking lifters · New plugs and wires · 2nd Gen Mas air and intake K&N filter · Hard pipes and Front mount Intercooler · Powder coated Valve Cover · SS Brake lines · Cross drilled Rotors all 4 corners · 3 in. Turbo back with high flow Cat. · Rebuilt Trans and syncros · Spec Clutch Fadanza Flywheel · SS Clutch cable · Shifter bushings · TEL shifter with Evo shift knob · Rebuilt Transfer case · New Slave and Master Cylinder · Battery Relocated to trunk · Hyper Ground kit · HKS BOV · Turbosmart in cabin boost controller · Apexi turbo timer · Apexi AFC · Eprom ECU with Key Diver Chip · KYB Shocks with H&R springs · Tien camber plates · 17in Konig Helium Wheels and the stock wheels · Whiteline Sway bars front and rear · New front axle · Front and rear strut tower bars · Boost gauge in dash and Mitsu. Gauge kit · 93 Head lights · Clear corner lights · MMC badge · Tinted windows · Evo IX steering Wheel · Euro Grill with driving lights · No AC I had it removed
-1992 Mitsubishi Galant VR4 107/1000
-2008 Mitsubishi Endeavor Special Edition
-2009 Dodge Ram 1500 4wd
Posts: 122 | From: PA | Member Since: 02/10/09 | IP: (67.239.60.143) |
1 registered and
0 anonymous users are browsing this forum.
