Jeff's 1991 VR4 1881/2000
jepherz
KC, Missouri
Interior
VR6Eater leather shift boot
DSM shifter arm
Custom aluminum shifter base bushings
VDO EGT gauge
VDO Oil pressure gauge
VDO boost/vacuum gauge
Leather Eclipse steering wheel
Exterior
Blacked out door trim
Liquid coated black evo8 17x8 wheels
Suspension/Handling
Falken Azenis 235/45/17 tires
Hotbits coil over suspension w/ external reservoirs
Full Energy suspension subframe bushing kit
Whiteline front caster bushings
Whiteline 24mm front sway bar
Whiteline 26mm adjustable rear sway bar
Custom 11.3:1 steering
Brakes
Cobra 13" front rotors
Camaro Z28 front brake calipers
Stainless steel brake lines
Power
EvoIII 16g turbo
Ported 2g exhaust manifold
Ported 2g o2 housing
Custom 3" mandrel bent stainless steel exhaust
Slim JoeP boost controller
Intake
Spearco 2-120 front mount intercooler with custom endtanks
Custom 2.5" aluminum intercooler piping
3" mandrel bent aluminum intake pipe
K&N air filter
Drivetrain
RPS 2900 performance clutch
3-bolt LSD rear differential
5 lug hub swap
Fuel
Rewired Walbro HP 255LPH in-tank fuel pump
PTE 780cc injectors
Earls -6AN high flow fuel filter
Aeromotive -6AN AFPR
Custom -6AN welded fuel rail
Tuning
Moates Ostrich eprom emulator v10.0
Innovate LC-1 Wideband O2 sensor
Other
3g 485 MAF
Trunk relocated small battery with custom aluminum battery box
Deleted ABS
Deleted AWS
Custom stainless steel exhaust manifold heat shield
Slimline radiator fan
