Name: Christopher Paul Besso
Board Name: Besso
Modifications
Engine:
-JDM 4G63 Engine w/ Cyclone Intake Manifold
-3G #482 MAF and IceMan Connector Harness
-K&N RT-4610 4.5" Titanium air Filter
-Vibrant aluminum 3G MAS Adapter
-560cc Denso EVO VIII Injectors (Flow Tested by Cruizin Performance)
new OEM Isolators and Fuel Filter also installed
-Polished Throttle body elbow and replaced newer JDM Throttle Body
-Magnacore 10mm Spark plug wires and NGK BSE7's with a .029" gap
-Joe P. MBC with ZX Uprgrade
-External Oil cooler
-Mofugas 2 1/2" stainless Turbo Back exhaust with a Magnaflow single tip muffler
Electronics / ECU / Fuel Management:
-Keydiver Stage 3 Dual Image EPROM
socketed by: PowerPlay (capacitors have also been replaced)
-Cyclone canister on purge valve
-Palm III-C running MMCD w. Auto on ALDL OBD-I cable
-Cruise controle deleted
-Apex'i Black SAFC-II Tuned by KTR Performance
-UltraTimer JDM Turbo Timer in the ashtray
Drivetrain/Suspension:
-Whiteline 26mm rear Sway bar
-Replaced most 4WS Lines and used Mobil-1 DOT 3 brake Fluid
-MD733623 - 91' Slave Cylinder
-Mofugas short throw shifter
-Newer OEM Clutch
-Cross Drilled / Slotted front rotors
Exterior / Body:
-JDM RS Grill
-89 GS Bumper Lenses
-JDM Dual Bulb Clear corners (wired into turn signals and running lights)
-PIAA Xtreme White Plus 9006's
-TC Sportline OEM Carbon Fiber Hood
-Sunroof Visor
-Stock wheels are painted gray (has BF Goodrich traction T/A's)
Interior:
-Fiberglass dual Pillar Gauge Pod (made by Paulo)
-Defi D-Gauge series Boost Gauge
-Autometer A/F Gauge
-Alpine CDE-9870 deck ft. KCE-422i iPod adapter w/ Boston Acoustics all the way around
-MOMO Race 350mm steering wheel, hub adapter, and Niken Pedals
-Arkon PDA Holder
-VR6 Eater leather Shift Boot
-MOMO short Anatomic shift knob
Board Name: Besso
Modifications
Engine:
-Newer OEM Clutch
Exterior / Body:
-JDM RS Grill
-Sunroof Visor
Interior:
-Arkon PDA Holder
