FS: cams,pistons,rods,etc
bigblock4g63
new jersey
------ please read before looking at post -----------------
there is shipping and paypal fee on all parts
1. I will only hold parts for people who leave dp.
2. If you leave a dp and then later back out you will lose your dp.
3. I do have paypal
4. If you have flaked out on something i am saleing. I will not deal with you in the future.
5. Pm 'ing me and telling me you want the part buy not paying for it does not mean you own the part.
6. Dont sh*t up my post.
7. I am not saleing knock off parts if you want knock off parts go to ebay
8. Again money talks and b.s walks
9. Buyers will get a tracking number
10. Thank you for taking the time to read everthing.
11. If you pay for something and i ship or give you the parts then later want a refund its not going to happend,
12. Let me know what is your screen name is and what forum you are from
13. I have seen a person using my pics as there own to sale parts so if anyone see that just let me know
14. Iam not looking to trade anything
15. 908 884 8720
Garret GT 35R with upgrade comp saleing with two turbine housing T4 .68 and T3 63 * used on dyno* $1200.00
GT4094R with .85 tubine housing coated in silver $1400.00 *used on dyno* -sale pending -
less then 20 runs on both turbos
HKS 264 INTAKE CAM - NEW PART- $320.00
CUSTOM CYRO REGROUND 272 EXHAUST CAM $175.00
MORALES RACING VENOILA SPEC PISTONS FOR A 6-BOLT 20 OVER $750.00 - NEW PART -
SNOW METH KIT STAGE 2 KIT $325.00 - NEW PART-
HYUNDAI VALVE COVER IN RED $85.00
S90 THROTTLE BODY 70MM WITH HARDWARE AND GASKET $270.00 - NEW PART -
ENGINE TORQUE LIMITER KIT $55.00 -NEW PART-
BC 272 CAMS *USED FOR DYNO LESS THEN 50 MILES ON THEM* $275.00 -lower to $265.00
MANLEY STOKER PISTON #607005 *SINGLE PISTON ONLY* 20 OVER -NEW PART- $118.00
MANLEY ROD 6-BOLT #14021 *SINGLE ROD ONLY* $80.00
HALLMAN PRO BOOST MBC -IN RED- NEW PART- $110.00
ZEX NITROUS BLANKET - NEW PART- $35.00
OEM 3000GT VR4 BOV $15.00 -used-
TOPLINE PISTONS #PAMI-23T 020 -NEW PART- $160.00
Rci seat with black cover $55.00 - new part-
will not ship, pick up only
Crower springs *SINGLE NOT DUAL* $85.00 - NEW PART-
Manley Performance Pistons w/ Rings (8.5:1 C.R.): Mitsubishi Eclipse 6-Bolt with coated skirts 20 over - new part -
$430.00
MORALES RACING 4G63 EGR BLOCK OFF KIT WITH OEM GASKET AND HARDWARE $22.00 shipped
JE Forged Piston w/ Rings (8.5:1): Mitsubishi Eclipse 6-Bolt 20 over - new part - THIS IS A SINGLE PISTON ONLY
$170.00
MORALES RACING CATCH KIT WITH PRE-FILTER $90.00 - new part -
MAGNUS 70mm throttle body with gasket $200.00 - new part -
X-BOOST DOWNPIPE ADAPTER 2.5'' TO 3'' INCH $25.00 - NEW PART -
MORALES RACING PORTED 2GEN INTAKE MANIFOLD WITH EGR BLOCK OFF KIT $130.00
1GEN STOCK 02 HOUSING -USED- $25.00
1GEN STOCK FUEL RAIL WITH WELDED 8AN FITTINGS ON BOTH SIDES -USED- JUST SAND BLASTED $30.00
TIAL Q BOV *REAL NOT A KNOCK OFF* IN SILVER -NEW PART- $260.00
X-BOOST CATCH CAN *IN SILVER MISSING SOME PAINT* -NEW PART- $30.00
X-BOOST VACCUM BLOCK 7-PORT IN SILVER -NEW PART- $23.00
2GEN EXHAUST MANIFOLD PORTED WITH EGT FITTING -USED- JUST CLEANED AND SAND BLAST $70.00
TIAL 46MM WASTEGATE *REAL NOT A KNOCK OFF* IN SILVER -NEW PART- $490.00
TIAL 40MM WASTEGATE *REAL NOT A KNOCK OFF* IN SILVER -NEW PART- $390.00
MORALES RACING SX FUEL FITLER REBUILD KIT $25.00
MORALES RACING VENOM FUEL RAIL INSTALL KIT $12.00
T.N.T SINGLE FOGGER NITROUS KIT-BLUE PRINTED BY DARKSIDE NITROUS -NEW PART- $500.00
MORALES RACING 1GEN PORTED INTAKE MANIFOLD WITH EGR BLOCK OFF KIT -JUST SAND BLASTED- $130.00
bigblock4g63
new jersey
pm's answered
bigblock4g63
new jersey
Morales Racing Spec Venolia forged piston with rings/lock and heavy duty pins with custom machined pin oilers
20 Ove * 6-bolt * 7.5:1 comp $750.00 have four sets
bigblock4g63
new jersey
yes on the turbos being used
bigblock4g63
new jersey
20 Over * 6-bolt * 7.5:1 comp $750.00
JUST GOT ANOTHER 4 KITS IN
bigblock4g63
new jersey
Manley pistons n rods combo $700.00 6bolt 20 over same as above and rods are h beams "PARTS ARE NEW" *i myself have made over 500hp with manley set
t.n.t single fogger nitrous kit-blue printed by darkside nitrous zex bottle blanket combo -new part- $500.00
i dont remember who ask me about it but that is the price..thanks
bigblock4g63
new jersey
any ques just give me a call 908 884 8720
bigblock4g63
new jersey
---UPDATED-----
all pm returned and all parts shipped
hogan 2000 DESIGN intake manifold -NEW IN THE BOX- SOLD
Q45 90mm Throttle Body $120.00 -used- or $140.00 with pigtails
bigblock4g63
new jersey
updated...
custom arias pistons kit 6-bolt 60 over $525.00
and
arias pistons kit 6 bolt 20 over $500.00
ARIAS PISTONS has been the leader in compact piston technology since our beginnings. While piston suppliers at that time focused mostly on larger-bore domestic V-8’s, ARIAS had the foresight to cater to the smaller-bore, higher-revving, hotter-running imports & domestic compacts.
Today, ARIAS maintains an unmatched advantage in the import and domestic compact market. Over three decades of research and development have led to the ARIAS Sport Compact shelf line.
- Hi-tensile forged, not cast, billet material
(4032 or 2618).
- CNC machined working surfaces.
- Optimized crowns for efficient combustion.
- Diamond-turned ellipsoidal skirt profile.
- All motor/Nitrous pistons feature lightweight, high strength construction.
- Turbo/Nitrous pistons feature durable, heavy-duty design.
Sport Compact
stocking kits include:
- Forged pistons with pin fit.
- Wrist pins: High carbon,
case-hardened.
- Ring set: chrome or moly faced top, cast 2nd, 3-piece oil.
- Locks: carbon steel wire or spiral.
Fits: 1st Gen Eclipse/Talon 6-Bolt Motors
Stroke: 3.465
Rod Length: 5.906
Head cc: 47.0
Compression Height: 1.375
Dome CC -11.0
Compression Ratio: 8.7:1
Gram Wight: 365
Wrist Pin Diameter: .827"
bigblock4g63
new jersey
have some back issue of over rev mag with brent rau eclipse, has some good info on the car and about him plus inside of turbonetics and cage info
$9.00 bucks each with shipping
bigblock4g63
new jersey
updated list
all p.m reply
all parts shipped
all phone calls returned
and HOGANS 2011 DESIGN INTAKE MANIFOLD WITH NITROUS BUNGS $800.00 GOOES FOR OVER $1400.00
bigblock4g63
new jersey
HOGANS INTAKE MAIFOLD SOLD...ALL PM'S REPLY...CALLS RETURNED..PARTS SHIPPED..
bigblock4g63
new jersey
updated
bigblock4g63
new jersey
yes sir will sent pic 2morrow when i get back home
bigblock4g63
new jersey
bigblock4g63
new jersey
the hks 264 intake cam...is off for now
talontyme
Portsmouth,VA.
What size are the an ports on the catch can.
