FS: Loctite Nickel Anti-Seize $2!!!!!!
So I needed some Nickel antiseize for my turbo/manifold bolts and the only size they had was 1lb!! So $45 later I have a full tub of it. If you have trouble with your turbo/manifold bolts backing out or you are doing any turbo or manifold swap or install you NEED this stuff when reassembling, it withstands up to 2400*f. This is not the Permatex this is the real deal Loctite.
For $2 you get a spoonful(enough to last a long time) in a ziplock baggy, shipped in a plain envelope. Please just paypal [email protected] and title the payment "Antiseize", I will put envelopes in my mailbox sameday.
omertaitalia
Downtown Los Angeles CA/Lake Tahoe,CA
how come you didnt lace 435's manifolds with this...i need some, exhaust manifold studs wont stop coming out im tightening every 2 days
TRBODSM
Northglenn, CO
^^^ Do you have the washers for the turbo bolts? Turbo manifold to turbine housing should have 2 washers per bolt.
I dont remember having an issue with 435. You should definately try the cupped 2g washers.
btw heres a pic of shipped product,
Quoting omertaitalia:
Anti-seize isn't going to keep the bolts from backing out. You need the proper bolts/washers.
