FS: NEW 3000GT VR4 Big Brake Kit/ External Fuel Pump/ Misc. Items
vapid
IL
Prices do not reflect paypal fee and shipping.
New (only mounted) 3000GT VR4 front brake "kit"- $SOLD
New calipers
New ATE pads
New Powerslot Cryo-treated rotors
New SS lines (front only)
Adapter brackets
(I also have new rear calipers if interested)
BNIB 2G AWD 3" SS Megan Downpipe (will fit, and eliminates cat on GVR4)- $100
BNIB Fuelab Prodigy In-line fuel pump (140GPH 1300Hp)( link ) - $375
New 2G Clutch line (master to slave, will fit GVR4/1G)-SOLD
BNIB Isuzu slave cylinder- $40
New OEM Steering rack cushion (MB315228)- $7
New (2)OEM Front crossmember bushings (MB518168)- $20
New AFPR install kit- $40
Used (500mi)ARP Head studs- SOLD
Used OEM Knock sensor (worked when I took it out)- $10
New DIN+SAFC Face plate- SOLD
Used OEM spark plug cover (decent shape)- $15
New (2) Vibrant 3" aluminum 90 degree elbows- $40
Used (500mi)Turbo Oil feed line- SOLD
Used 1G Fuel rail-$10
Used 1G Fuel rail w/ -6an end- $15
New ETS 2"-2.25" reducer- $10
Used 2"-2.75 reducer- $10
New ETS 2" 45 elbow- $20
Powdercoated alt. bracket- $10
Used Symborski shifter bushings- $SOLD
Used (approx. 500mi.)Taylor spark plug wires- $20
New Jegs -8an straight push-lock fittings (4)- $15
New Jegs -6an straight push-lock fittings (3)- $5
New Earls fittings
-8an to 1/2in. (700109)- $3
-8an to #10 o-ring (2)(AT985081)- $10
-6an port plug (AT581406)-$3
-8an bulkhead fitting and nut (AT983208,AT992408)- $7.50
-6an to 14mm x 1.5 (991954)(good for 4ws rack block-off)- $5
-6an to 3/8 tube (165006)- $7
-8an (m) to -6an (f) - $7.50
-6an (m)to 14mm x 1.5 (f)- $5
New Jegs push-lock -8an hose (10ft)- $20
vapid
IL
Bump
vtecds1
Las Begas
50 lbs of Longanisa and 10 dozen eggs for the Maft kit. Let me know...
vapid
IL
Mmmmmmm.......Longanisa. Throw in a couple dozen siopao, and you may sway me!
vapid
IL
ttt
vapid
IL
Parts added.
mountaineerjeff
west virginia
i thought some 16s would clear?
JSchleim18
Long Island, NY
16x8 +38 or better *should* clear depending on spoke design
vapid
IL
All pm's responded to, and pictures added.
Do you have a pocketlogger still,I want to buy the whole set up or just the cable and software, I have a Palm.
alansupra94
Wayne,NJ
So that is an external fuel pump? Does it need a special fuel tank to operate? I could use something like this for my supra when I convert over to ethanol.
Thanks,
Alan
vapid
IL
No, it does not need a special tank to operate, assuming you're going to keep your in-tank pump.
However, you would have to figure out how you're going to feed it from your sending unit.
vapid
IL
Updated.
vapid
IL
bump
vapid
IL
Parts added and updated.
vapid
IL
Parts added and updated, again.
