OFFICIAL: Part Out of 1157/2000 *Updated 3/9* **DELETE**
JSchleim18
Long Island, NY
**PART OUT IS COMPLETE AND EVERYTHING IS LISTED**
*ALL PRICES ARE SHIPPED PRICES UNLESS NOTED; CAN SHIP WORLDWIDE*
Pictures can be found here: click
Don't forget to check out my other for sale listing here: click
Here is a list of the parts:
Engine/Drivetrain:
1G DSM/GVR-4 coil pack - $20
Custom OEM 1G DSM radiator hoses for GVR-4 for Scirocco radiator - $30
Engine Fuse Box Cover - $15
Front OEM 5 lug dual piston blank rotors (like new) - $50
Fuel rail spacers - $10
GVR-4/1G DSM Gusset plate por15'd - $40
Injector resistor box - $15
MPI Relay - $30
OEM Power Steering Belt - $10
Power Steering Pump - $40
Power transistor - $15
Starter - $30
Interior:
Door lock tabs - $5 each
Door panel door handles - $15 each
Driver side interior cover for mirror - $10
trunk release - $20
HVAC panel - $20 each
Instrument Gauge Cluster Surround - $20
Interior Chrome door handles - $15 each
Interior plastic panels behind the chrome door handles - $5 each
Mirror switch - $10 each
Passenger window switches - $10 each
Passenger Side Kick Panel - $15
Rear door ashtrays - $10 each
Rear view mirror - $20
Rubber ring around ignition key - $5
Under dash fuse panel cover - $10
Exterior:
Bumper filler panel - $20 PLUS SHIPPING
Driver Side Mirror - $40
Eclipse 2G GS-T wheels + Dunlop Wintersport M3 Tires (205/55/16) - $400 PLUS SHIPPING
Front Cowl - $20 PLUS SHIPPING
GVR-4 pass side skirt rocker panel - $20 PLUS SHIPPING
GVR-4 quarter windows - $30 each
Hood prop - $20 PLUS SHIPPING
Wing - $40 PLUS SHIPPING
SOLD:
Blacktop CAS - $50 *SOLD*
New Clutch Master Cylinder - $40 *SOLD*
2G 3Speed Scatter Shield - $100 *SOLD*
Zaklee Cam Gear Cover - $50 *SOLD*
Prothane Motor Mounts Pressed in GVR-4 Mounts - $100 *SOLD*
Jay Racing Saturn Alternator Relocation Kit - $200 with Alt. *SOLD*
AC Delco Saturn Alternator (comes with relocation kit) *SOLD*
Tein HA Coilovers - $750 plus shipping *SOLD*
5 lug setup with new OEM bearings - $150 *SOLD*
Whiteline 22mm Front Swaybar & Bushings - $150 plus shipping *SOLD*
Whiteline 26mm Rear adj. Swaybar & Bushings - $175 plus shipping *SOLD*
Whiteline Spherical Endlinks - $100 *SOLD*
Whiteline W0623 - $50 *SOLD*
Whiteline KCA321 Front Caster Correction Bushings - $40 *SOLD*
Alum Driveshaft Bushings - $30 *SOLD*
Power steering rack with new Moog tie rod ends and boots - $150 plus shipping *SOLD*
Catch Can Setup: $150 *SOLD*
‘90 N/T Waterpipe - $40 *SOLD*
Power Enterprise Rad Cap - $10 *SOLD*
Greddy V1 52mm Boost, Oil Pressure, Oil & Water Temp Gauges - $400 *SOLD*
AEM Wideband Gauge - $150 *SOLD*
Throttlebodys.com Rebuilt N/T Throttle Body - $100 *SOLD*
Intercooler Kit: $750 plus shipping *SOLD*
BR 20G Turbocharger - $400 *SOLD*
FP Manifold Ceramic Coated - $150 *SOLD*
Exhaust: $400 Local pickup only for now *SOLD*
Engine: $1,800 *SOLD*
Spo/No switch - $20 *SOLD*
Eco/Pwr switch - $20 *SOLD*
89 Underdash & Glove Box in correct color - $70 *SOLD*
Custom Floormats - $50 *SOLD*
Aeroworks Fiberglass A-pillar 52mm gauge Holder - $50 *SOLD*
1993 headlights - $175 *SOLD*
JDM Amber Corners - $75 *SOLD*
JDM Eterna Grille - $150 *SOLD*
Seats - $150 plus shipping *SOLD*
Steering Wheel - $40 *SOLD*
Dash Badge plus replica keychain - $150 *SOLD*
Leather arm rest - $20 *SOLD*
Cup Holder - $10 *SOLD*
Power Antenna - $50 *SOLD*
Comp Clutch Flywheel (steel like the ACT flywheel) - $100 *SOLD*
Fuel Lab FPR Kit - $190 *SOLD*
Candy Red over Chrome GVR-4 Valve Cover - $100 **SOLD**
‘90 Oil Filter Housing - $60 *SOLD*
B&M Oil Cooler Setup (cooler, lines, fittings, mount) - $140 *SOLD*
JL Audio E4300 Amp - $60 *SOLD*
JL Audio E2150 Amp - $40 *SOLD*
MB Quart RWE 160 rear speakers - $80 (includes RXE216 crossovers) *SOLD*
MB Quart RWE 130 front door speakers - $60 (includes RXE216 crossovers) **SOLD*
Pioneer RS-A878 - $20 *SOLD*
SBR o2 Housing Jet-Hot Tial 38mm Wastegate w/ new Denso o2 Sensor - $300 *SOLD*
Battery Relocation Kit $200 *SOLD*
JDM RS hood (Fiberglass) - $250 with Aerocatch locking hood pins plus shipping *SOLD*
Fuel Sending Unit - $100 *SOLD*
ECMLink V3 Lite Package (includes GM Delphi 3 bar MAP & IAT Sensors, Full Throttle 1G/GVR-4 speed density harness) - $475 *SOLD*
Galant VR-4 EPROM ECU already socketed - $150 *SOLD*
JDM RS front bumper - $450 *SOLD*
AFCO Scirocco Aluminum Radiator, Perma-Cool Fan, Custom Aluminum Shroud - $400 *SOLD*
TRE Stage 2 2nd Gen Trans - $800 plus shipping *SOLD*
GVR-4 Transfer Case - $100 *SOLD*
Hallman PRO MBC in Black - $65 *SOLD*
Instrument Gauge Cluster (100K miles) - $40 *SOLD*
Rear deck speaker covers - $15 each *SOLD*
Trunk Badges (VR-4 included) - $30 *SOLD*
Smoked door panel light covers - $20 for the set *SOLD*
Driver side window switch - $60 *SOLD*
1G DSM Shifter Boot - $10 *SOLD*
Denso 720cc Injectors - $150 *SOLD*
Denso TT Supra Fuel Pump - $75 *SOLD*
4 Bolt LSD Manual Rear with axles and cups - $300 PLUS SHIPPING *SOLD*
Competition Clutch 1620 Stage 4 Clutch - $200 *SOLD*
Alpine CDA-9835 CD/MP3 Player - $200 *SOLD*
1991 Tails - $100 *SOLD*
Clock - $15 *SOLD*
Complete set of locks (doors, fuel door, trunk, keys included) - $100 *SOLD*
Fuel Door - $20 *SOLD*
Autozone front axles (500 miles) - $50 PLUS SHIPPING *SOLD*
JDM RS Rear Bumper - $350 *SOLD*
Magnecor 8.5mm Wires - $60 *SOLD*
Non-ABS Conversion Kit (Galant GS-X Prop Valve) - $60 *SOLD*
Gas tank fill tube (the metal piece that attaches to the body of the car) - $40 *SOLD*
Custom Alum 4” intake Pipe + K&N 4” Intake Filter + NEW K&N Filter Cleaner - $120 **SOLD**
Doglegs - $50 for the set **SOLD**
JDM Projector Fog Lights - $200 **SOLD**
DSG White Shift Knob - $20 **SOLD**
Fog light switch - $20 **SOLD**
GVR-4 1991 Owner's Manual - $30 **SOLD**
spare tire cover - $20 PLUS SHIPPING **SOLD**
Gas Tank - $150 PLUS SHIPPING **SOLD**
GVR-4 coolant reservoir - $20 **SOLD**
1G DSM Shift Knob - $15 **SOLD**
Ashtray - $10 with lighter **SOLD**
Binary Engineering black shift knob - $40 **SOLD**
Clock - $15 **SOLD**
Dashboard speaker covers - $10 each **SOLD**
Defroster switch - $10 **SOLD**
Dome Lights - $30 **SOLD**
Hi there, do you happen to have a power steering feed tube line by the rear differential and the valve? Its part number mb616531.
Looks like this.
citymunky
Chesapeake, VA
The last time I PM'ed you I wanted your rear JDM bumper, but I already found one.
I'll be down these items form the Battery Relocation:
Summit Racing Box
1 Gauge P/N Cables
4 Gauge Alternator Cables
Longacre cut off switch
Street Wires Dist. Block & P/N Battery Terminals
and I assume the Boostx Subframe bushings & Mustache bushings were never installed. if so I need those too.
GVR4ZUM
SoCal, USA
How much for the following?
Zaklee Cam Gear Cover.
JDM Door handle Replica protector.
JSchleim18
Long Island, NY
I added prices to the thread just to give everyone an idea of how much I will be looking for.
Prices are shipped unless noted.
presterone
brunswick maine
Is this a former DSG car? I Need the rear adj. control arms, rear and possibly front swaybar and the oil cooler if it will work with my 92 GVR4 oil filter housing
JSchleim18
Long Island, NY
Quoting ebonix:
Any news on the part I posted? :)
Hey I'm sorry I thought I replied. I do not have that part sorry. I deleted AWS and threw all that out.
Oh okay... Noob question but.. What did you replace all that with? Mine's still stock and hard to find the parts now...
JSchleim18
Long Island, NY
Simply used a 1G DSM (eclipse, talon, or laser AWD) subframe
rmontalvo23
Fort Lauderdale, FL
I would be very interested in the engine depending on the mileage and confirming Compression test.
Hit me up if you actual decide to sell.
988
Malaysia
hai jeremy....can post pic's that 93 headlight.... and price...is that 93 headlight is crystal? Thanks....
JSchleim18
Long Island, NY
JDM RS Front Bumper (with fogs, curtis brackets, and the black strip that comes with the RS bumper) - $750 SHIPPED
JDM Rear Bumper - $500 SHIPPED
