TheWolf
(Newbie)
04/15/18 10:33 PM
JDM Galant VR4 Chime
I have a 1987 JDM Galant VR4 RHD. When I get to 65mph it chimes until the speed decreases below 65mph. Someone must know how to easily disable this. Driving under 65mph is certainly not a viable option...lol
kumfasa
(Member)
04/15/18 10:45 PM
Re: JDM Galant VR4 Chime
I too have a JDM VR4 and I am pretty sure that no VR4 ever came with a speed warning chime from the factory.
Whatever it is making the noise at 65mph it is likely to be aftermarket. If you start poking around under the dash you should be able to track down the non-factory looking wires.
Good Luck.
G
(JDM Unit)
04/15/18 11:21 PM
Yeah it did come with that, mazdas did as well. I believe you have to remove the cluster and unplug the chime.
brisvr4
(Oceania Distict Enforcer for the Galant VR4 Mafia)
04/15/18 11:58 PM
There is a screw on the back of the cluster with a wire that you need to remove.
The pic in JDM Chime this link will work if you click it!
bobdole
(Old member with new to me VR4 and starting over. Respect your elders kids)
04/16/18 12:22 PM
Really? Guess I need to go over 65mph see if mine has.
("Just to be pedantic!")
04/16/18 07:16 PM
Only the early model VR-4s have it, I think it was around 1988 when the law in Japan requiring a 105km/h chime was abolished.
You can hear the chime in this cheesy 1987 promo video - click
kumfasa
(Member)
04/18/18 06:12 AM
My bad.
TheWolf
(Newbie)
04/22/18 03:52 PM
Thank you so much. Was super annoying on the highway. Super easy fix!!!
boostme
(Junior Member)
04/23/18 03:43 AM
That's JDM as a MF'R... got any pics? I'm like an hour away. Great to see a "local"
TheWolf
(Newbie)
04/24/18 12:36 PM
Yes Sir! It's a 1987 JDM Galant VR4. I will post a few pics when I get home from work.
misterfixit
(Victory Runner)
05/12/18 03:49 PM
if you take off the climate control surround, the chime is just behind the grille part on the lower right of the frame. The grille is present on both twiddly dial and pushbutton types.
Its a 2 pin flat blade yazaki connector (white). The chime screws into the dash carcass from the heater box side but you should be able to just pull the connector.
Kind regards,
Rich
P.S. Mine is still hooked up, but I have a switch inline for 'jdmness' so I can turn it on and off.
(Turn Right Racing)
05/14/18 12:29 PM
"I have a switch inline for 'jdmness' "
Oh, I need to sell these on ebay! Think of the suckers...
misterfixit
(Victory Runner)
05/14/18 03:43 PM
It's a headlight height adjuster switch. So It's possible to turn it on.. and off when it becomes annoying.
Truth be told it's mostly off.
Generated in 0.008 seconds in which 0.006 seconds were spent on a total of 4 queries. Turbo powered.
