cachacuas98
(Newbie)
03/31/18 03:46 PM
head
Is the same head non turbo 4g63 then the one on 4g63t? please If anybody knows I need a core for a 4g63t. thanks
(Senior Member)
03/31/18 06:17 PM
Re: head
All 2.0 heads are the same between 1989 and june of 1992. After that they use smaller head bolts. After june 1994 they get smaller intake ports.
(Senior Member)
03/31/18 06:18 PM
Re: head
Cams are different.
cachacuas98
(Newbie)
03/31/18 11:34 PM
Re: head
thank you!
FlyingEagle
(Eager Beaver)
04/02/18 09:43 AM
Re: head
You can find a 4g67 head/1.8L Elantra (will have a 1.8l on the thermostat side of the head), and it will have a smaller CC combustion chamber, but has options for the larger diameter intake and exhaust ports; some had smaller intake ports like a 4g61t intake manifold. This would bump compression is you are looking to tweak things a little bit.
Otherwise as stated, you can use any non-turbo head with a 2.0l on the thermostat side of the head, assuming the correct era of casting.
Generated in 0.009 seconds in which 0.008 seconds were spent on a total of 4 queries. Turbo powered.
