(Senior Member)
12/12/17 01:12 PM
Wheel + hub cone = wabble
I have evo x wheels and need 5mm spacers upfront to turn lock to lock. The rims have a taper cut in to them in the hub area, and because of this and the spacer the rims do not contact the hub to center it. What if anything can I do to fix this?
(Turn Right Racing)
12/12/17 03:15 PM
Re: Wheel + hub cone = wabble
Hubcentric spacers. I ordered some from ebay a long time ago. They basically have a machined center lip that matches the hub diameter to center the wheel on the spacer the same as it would on the hub.
(Senior Member)
12/12/17 05:13 PM
I can't find that in 5mm
(Turn Right Racing)
12/21/17 08:01 AM
Charles of B2 Auto Designs (Bob Dole on here) has these on his web site.
spacers
(Senior Member)
02/10/18 03:58 PM
The picture for 5mm is a generic. There's no place for a ring to go on a spacer so thin. I'm going to try to get some 59mm to 67.1mm rings, and turn them down to fit the interior ring of the hub. Like an extension. I can't find an off the shelf solution... Like usual.
Generated in 0.003 seconds in which 0.002 seconds were spent on a total of 4 queries. Turbo powered.
