galantrevolution
(Member)
10/02/17 09:36 AM
Cat delete for a JDM galant
Where can I find a cat delete for my JDM galant , since there is a sensor in the cat
Defiant
(Definitely? Defiantly? wat)
10/02/17 09:57 AM
Re: Cat delete for a JDM galant
The sensor should be right before the cat.
A test pipe should do the job.
G
(obsessed with the turds of others)
10/02/17 09:59 PM
The sensor is not needed. It's just an overheat sensor that lights up on the dash if your cat gets too hot. I just zip tied mine up out of the way. There is a little cage you can tuck it up into.
galantrevolution
(Member)
10/03/17 08:35 AM
Ok , I just don't want to have an engine light on
G
10/03/17 09:39 AM
No you won't.
(Turn Right Racing)
10/03/17 02:37 PM
Correct. You are not disconnecting the circuit, but rather keeping the sensor from sensing the temperature, which is what turns the trans overheat light on.
G
10/03/17 06:36 PM
You mean cat light.
(Turn Right Racing)
10/03/17 08:31 PM
Yeah, that.
