ade
(Carbon Fiber Phallus Group Buy Member)
02/11/12 02:51 PM
New New Yorker taking on a gvr4
picked it up from CT and brought it home to long island a few weeks ago, fuel systems fucked, leaky 4ws, and the worst squirrel infested car i'v ever had the pleasure of owning.
question?
are 95 gsx rear ends, spindles, brakes and steering rack swappable?
And i need a gvr4 filler neck, sending unit and tank, a 3" muffler(Borla preferred) and 3" cat, new or used.
citymunky
(Fake Title)
02/11/12 03:14 PM
Re: New New Yorker taking on a gvr4
What is in the A/C vents?
BluFalcon
(Fantastic Parts Seller)
02/11/12 03:29 PM
Squirrel Condo.
Diego
(Mad Hatter Suite Touche Debackle Guage filled by Justin)
02/11/12 03:59 PM
Quoting ade:
question?
1.91/94 1Gs would be your better catch of a rear end swap...
2.Filler neck can be bought on JNZ new for $48.00 click
3. Fuel tank.... good luck, check junk yards for Galant GSX's they were 4wd as well so I would fathom that they should be interchangeable.
4. Cat I would also look for in a junkyard or place a WTB here on the board for one.
Thanks for joining... now do the car justice.
Diego
quicktsi
(Member)
02/11/12 07:01 PM
Mine preferred the intake manifold area. I did have droppings in the blower motor fan area though. What kind of damage did they do to the wiring?
AnotherNewb
(flutterdumper)
02/11/12 07:30 PM
Quoting ade:
Best introduction post EVER!!!
ade
02/12/12 11:51 AM
Ha yeah, im a funny guy
Quoting citymunky:
Quoting BluFalcon:
Squirrel Condo.
what he said.
Quoting Diego:
Diego
1. so the 95 which is a 2g rear end and power steering rack will not bolt on?
2. thank you. filler neck will be ordered if i find a stock fuel tank solution.
3. found one in the fs section, i'll be doing a search on this but what are gallant gxs's? i thought they were fwd's swapped to awd!
justice will prevail.
Quoting quicktsi:
squirrelly residents left my wires be, prev owner's on the other hand, yeeesh.
Diego
02/12/12 12:14 PM
Galant Vr4s 6th Gens were built on 1G platforms...2nd Gen T/E is on the 8th Gen Galant platform...3rd Gen Eclipse is on 10th Gen Galants.....
Ok now that is all clear...
Galant GSX were Awd... that is all.. they were just like the Vr4 but N/A...
Research....
Galantvr4559
(Member +)
02/12/12 07:40 PM
If there are no holes in the gas tank u can clean up the outside and paint it. For the inside of the fuel tank they make a three stage treatment to reline the inside of the tank. I did it to a motorcycle tank u just have to fallow directions on bottle. Check ebay or google to find the product. It is a good alternative to replacing the whole tank.
NYC86ZC
(30-Something)
02/12/12 08:24 PM
The tank doesnt look that bad. I dropped mine last week and POR15'ed it and welded on two new studs for the fuel sending unit. Good as new now.
Where on LI are you located?
ade
03/06/12 04:50 PM
Tank can not be saved, it was so pitted after sandblasting i wouldn't feel safe with it on the car. i got it running threw it on the lift to mocked up a 3" turbo back and found rusty brake, fuel, steering lines and a dirty under carriage. i have a 95 gsx shell i was going to pull both front and rear sub-frame's, axles, rotors, brakes etc from but i am yet to throw it on the lift to see whats swappable. I just opened up an auto & cycle shop and haven't found the time for the gvr4 so far the interior been cleaned out and that's it.
tall ars shifter was bugging me so off with its head.
Plans are to pull front and rear sub-frames, fuel, brake and steering lines.
See if the 95 gsx ps rack and front and rear sub-frame bolt on.
Clean up, spray sealant, rubberize the under carriage & wheel wells.
Fit new fuel and brake lines.
mock up 3" turbo back and fuel cell(utilizing the stock location & filler hole)
any1 have an opinion on sub-frame bushings? should i oem or upgrade?
i also plan to replace lines clean up and rebuild the rear steering unit
gtluke
(Fegbasket)
03/06/12 04:54 PM
2g suspension stuff won't work, at all. not even close. 1g stuff is a direct swap though.
ade
03/06/12 05:18 PM
i apologize for my hardheadedness, I'll listen to the forum members ova my doubts from now on. The car is gonna have to sit while i collect parts and make time for installs, I'll keep y'all posted.
GVR47111K
(slurpees, hot dogs and pickled eggs are still offered)
03/06/12 05:36 PM
Every time I see the title of this thread I think of Futurama. Old New York is underground and New New York is above it. So when I see the thread I think of a New New York citizen trying to fight a GVR4 transformer or something. A GVR4 transformer would be awesome.
BluFalcon
03/06/12 06:57 PM
If one were to name the car, I move to voice my nomination for "Squirrel Bait". I have yet to encounter a car that rodent infested, but you've done a pretty good job of cleaning it up. Looking forward to seeing more progress being made.
("Just to be pedantic!")
03/06/12 08:45 PM
Quoting Diego:
Research....
1G T/E/L were actually based on the 6G Galant platform not the other way around.
2G T/E was based on the 7G Galant platform which is also carried over to the JDM/World-spec 8G Galant with a few small changes, the US 8G Galant went away from the multi-link front suspension to macpherson struts like the 6G or Diamante. The 2G T/E definitely has multi-link up front.
The 3G Eclipse is based on the Chrysler Sebring platform, which I believe is loosely based on the US 8G Galant platform (macpherson struts at front and multi-link in the rear)
The 4G Eclipse is based on the 9G Galant. The 10G Galant isn't even released yet.
ade
03/09/12 06:15 PM
very educational.
Quoting GVR47111K:
thats what popped in mind when i named the thread:)
Quoting BluFalcon:
Hah squirrely wrath hehe.. unmm progress.... suuure, here u go.
ade
03/30/12 07:21 PM
time to get started on the under body. every line(brake/fuel/ps) needs replacing, so both sub frames are coming off for a sprucing.
we dont want to do this twice, so i put together a necessary sub frame sprucing parts list. This is where i need some luv,
did a lil searching and came up with the bellow, could use a little help finishing the list.
e brake cables @ ??
frt sub frame bushings @ ??
rear sub frame & mustache bushings @ click
SmoothCustomer
(Public school educated knowitall)
03/30/12 07:38 PM
E brake cables seem to be getting hard to get. Try Rock Auto. I recommend JNZ for those subframe bushings. Whatever you do DO NOT order from Tuners Nation. You will not receive your part.
ade
03/30/12 08:31 PM
ok thanks to smoothcustomer i've found both ebrake cables, and a front subframe bushing kit from jnz.
i'm still looking for a rear subframe bushing kit, i cant find it on jnz
SmoothCustomer
03/30/12 11:30 PM
Here you go: Click
ade
04/01/12 03:04 PM
Danke.
e brake cables @ jnz
frt sub frame bushings @ jnz
rear sub frame & mustache bushings @ Boostx
ade
05/31/12 04:04 PM
a few oem parts i have piling up
i couldn't wait any longer, under the bonnet looks sofaking drab
so i stareted sprucing up
fig i'll give the oll tb a cleaning also
aaaand im waiting on more parts
more as it comes, aye.
ade
06/04/12 02:03 AM
solving my fuel tank issue
still working on a mounting solution
citymunky
(Fake Title)
06/05/12 06:03 PM
mikus
(weiterhin das Huhn f#$k)
06/05/12 10:27 PM
great start compadre. Also ISWYDT regarding foamy
EDIT: this thread is worthless without Chrysler New Yorker drag racing.
ade
06/09/12 08:29 PM
lol yeah the gvr4 felt foamy's squirrely wrath.
sunny saturday afternoon, a $79 harbor freight flux wire welder and a close call almost loosing my hearing in my left ear to hot slag and she's in there.
center ov gravity's a bit higher back there but its as incognito as i could make it.
Vr4junkie
(writes like a tard)
06/10/12 06:29 AM
Nice build looks like this car is in good hands for once.
ade
07/14/12 10:03 PM
found out i r eprom
trying to fig out the T-housing puzzle
one ride after another, i heart wiring
inverted
cleans up nice
all this couldn't happen without jack
ade
07/15/12 02:07 PM
i haz almost fuel!
ghostinthevr4
(Likes Poetry)
07/15/12 05:29 PM
Awesome build going on what are your plans for the car? Fun daily, quartermile etc, etc. Either direction I'm sure it'll come out tits with you behind the helm.
ade
07/15/12 05:56 PM
Thanks, i picked her up with the intention of selling after building her, but i might hold onto er a bit longer. If so, she'll be a fun daily with the occasional quarter mile/road track visit.
I'm waiting on back ordered fittings so ill be tackling the brake & steering lines within the next few days.
ade
08/01/12 07:09 PM
hard lines done.
and more parts
ade
08/02/12 07:48 PM
made a sealed catch can out of an old fuel filter i had starring me down:)
Bonezilla
(Member)
08/04/12 01:03 AM
Props! Keep it up. Looks good. I wish I had my fuel setup for sale when you were doing this.
I noticed that your seat backs are all torn up. I have both seats that I would sell you cheap if you are interested. PM me if you are.
ade
08/04/12 03:27 AM
yeah the seats got a bit mauled by my squirrel hosts, but it looks worse in pics than in person. i just saw your feeler thread and would have offered my last project + cash for ur gvr4. seems a shame you have to let it go but i'm sure u have your reasons.
right before i sold er, i miss her but i had to let er go, shes in caring hands now.
ade
08/05/12 09:05 PM
shes coming together nicely
ade
08/05/12 09:20 PM
watched this lil guy crawl all over the gvr4 last nite
alansupra94
(Excuse the retarded question.)
08/05/12 09:45 PM
They are great pets. I raised one from an egg. Named him Jerry. One day Jerry was by the window and flew away (I thought they couldn't fly). A week later I see Jerry hanging out on the front of the house and then gets squashed by my little brother later when Jerry tried to get into the house on the door jam.
Stupid little brother.
ade
08/06/12 06:59 AM
heres to Jerry.
ade
08/13/12 08:08 PM
found room for the ic with a bit of remodeling for a better view
me thinks we have room for a set of minty oem fogs, any sellers?
my ic to do list
ic mounting brackets
box up the openings on the rebar or leave and spray bomb
pipe routing
bonnet latch brace
fan relocation
ps cooler rerouting
and then some.
JamesFoster
(Infamous BMX Master)
08/14/12 08:37 PM
I like your style, Ade.
ade
08/14/12 10:01 PM
cheers mate
ic is mounted
bonnet latch brace made
fan relocation done
ps cooler rerouting done
all thats lefts pipe routing
Vr4junkie
08/16/12 04:04 AM
Liking the intercooler setup what are the dimensions and brand.
faqinshiet
(Member +)
08/17/12 11:38 PM
Good job! Looks good
ade
08/19/12 03:57 PM
Thanks guys.
32 X 13 X 3.25 full
23.25 X 11" core
3" inlet
as for who made it? it was an off a buddy's dusty shelf, 100 dollar and its yours brand. But i know ebay when i see it.
4G63_GSR
(Member +++)
08/20/12 12:30 PM
Looks good! Quick question, how/where did you mount your IC? Did you make custom brackets?
ade
08/25/12 07:34 PM
iv been swamped with work, barely any sun when i get done with my nap, ill post up pics manana
**DONOTDELETE**
(Unregistered)
08/25/12 08:04 PM
the progress your making is awesome. Do you care to post up some pics of your i/c setup in regards to the piping? Im having a hell of a time trying to figure out a good way to route mine.
ade
08/26/12 02:59 AM
Quoting ade:
apparently i cant concentrate while dead tired.
i'll take and post pics of ic mounting and pipe routing later today.
ade
08/27/12 09:56 PM
top mounting points are bolted to a frame thats welded to the body. for the bottoms, i bent some steel to work with bolt holes already available. ive got to re adjust for a better bolt hold, use bigger washers then rattle can.
scooped up the goodies on the left ta replace those on the right
also i found this by the ecu. any1 have an idea what this plug is?
ade
08/29/12 12:14 AM
forgot about the pipes
throttle body, cold and hot side pipes are cut fit and ready for weld.
one 1g bpv flange
one 2.5" hump hose
one bending reducer
2 straight reducers 2.5" to 3"
08/29/12 11:13 AM
not 100% sure but that should be the o2 voltage output.. you can run a narrowband gauge to it for a reading.
16g16v
(Junior Member)
09/03/12 08:17 AM
The job you did so far with the I/C pipes looks fantastic. Great build man.
ade
09/03/12 11:06 PM
thanks brother, its hard not to rush through this semi build. I've been carless for almost 4 years, 3 of it was in the city where my fixie and Honda hawk got me to and from work and play. i now live in suburbia where u need a car to get anywhere. sux
When i picked it up last November, i thought i would strip the car down and take my sweet ass time putting it back together, yeah ok. All i look forward to now, is the day i push the pedal down and it goes. last thing i want is to go boom on that first drive, so im keeping a pace i know gives me time to attend to possible weak links as i kinda clean up the mess i paid for.
so far so good, i have about 2700(price of car included) into it. i've built road bikes twice that amount so yeah so far so good. i know i don't yap much on this thread, but i'ii make up for it in person, for im sure i'll meet a few of u and kill you slowly with endless questions.
A buddy stopped by today saw the car an said "when u gonna git that thang runnin" so i finished up the hood latch, front bumper & worked on the ic pipe routing a bit. we talked about going halvesies on a aluminum welder, we'll see(getting fed up ov waiting on people)
again so far so good, here is the remainder ov my list for those who care.
install ss brake lines
weld up ic piping
get alu 1g bpv flange
weld in flex pipe and wide band o2 bung
remove fix & reinstall rear steering hose
power steering pump rebuild
wiring to thermostat housing & fuel pump
find fuel gauge sender
install rear sub-frame bushings
build datalogger cable, pick up a palm
aaaaand... i forget.. there's always more:)
as usual i'll share as i go along.
Ade.
09/03/12 11:56 PM
if you want PM me i my have a palm laying around, at worst in about 2 or 3 weeks when im done playing with and finishing up 1365 i will have a palm and cable hook up i can sell ya for 55$ shipped... let me know.
ade
11/25/12 10:49 PM
well, its been a while, i know. sandy passed through leaving me alota work in er wake.
but before the storm, i installed the ss brake lines. i have to order shorter length fronts but the rears are mint.
found and installed a fuel gauge sender & tank breather
got in the last few exhaust and ic setup
got fed up with vein promises and outrageous prices so i ordered a tig welder, tank and supplies. also moving to my new stay with a nice garage. tune in, there's more coming soon.
citymunky
(Fake Title)
11/25/12 11:11 PM
Info on the tig welder. I'm looking into buying DC/AC tig welder with my income tax check.
ade
11/25/12 11:20 PM
here ya go click
ade
01/26/13 11:32 AM
been a while but got alot done.
made a few lists this was the most recent
minor port matching
cleaned up wiring & swapped old for new hoses
fabricated a box for the miata bosch
took a little massaging but made an sc34 at home
swapped out my steering wheel for a 380mm momo
89 grill
non usdm single bulb clear corners
ecmlink v3full
installed devils own meth kit
with more to come:)
Tre3zy
(correct me if im rite...Wyldcarz been rolling hard for a long time)
01/26/13 06:18 PM
glad to see the meth kit i sold you is installed
ade
01/28/13 12:25 AM
ill put it to work @tre3zy <-wish it worked on forums also.
cut and tacked up the exhaust last night.
putting the welder to work
newpoppop
(loves the form ride now)
01/28/13 08:52 AM
Nice Build, how bad was the original steering wheel? I am in the market for a decent leather one...
thanks
ade
01/28/13 02:32 PM
pm sent^
sometimes diy is best, im having a blast learning of and working on the car and cant wait till its first cruise.
ade
02/22/13 09:37 AM
LIV4PSI
(dyslexic 1051 )
02/22/13 01:31 PM
For the front SS brake lines, they look installed wrong. You are supposed to retain the OEM metal section that connects the lines together. And they should have a bracket that connects and wraps them around to the rear of the shock. That is probably why you have so much slack in your lines.
ade
02/24/13 11:17 AM
i did it all wrong on purpose and got rid of the oem metal section to run one ss line from the hard line to the caliper, unfortunately the front line was a bit long, rears are perfect. fortunately i ordered a shorter length, bye bye slack.
so i get to cleaning ina the trunk last night when i run into this. Hwaaaaaaa, could this be a source of a future melt down? not on my watch!
ade
03/03/13 04:05 PM
EROCK970
(Junior Member)
03/08/13 09:46 AM
Great looking car man. When u think u well have it running
ade
03/10/13 12:42 AM
thanks. i get it running next weekend, i get it to perfection in a few months.
EROCK970
(Junior Member)
03/10/13 11:06 AM
Nice man. I'm in NY too maybe we can meet up 1 day
ade
03/10/13 05:53 PM
meeting up someday sounds like a plan.
the turbo oil dump tube flange isnt getting shipped till the 23 so start up gets pushed back, more time to prepare imo.
EROCK970
(Junior Member)
03/10/13 06:28 PM
Ya I need a new clutch set up. Can buy it'd for the Nextel 3 weeks. So I feel ur pain
ade
04/11/13 05:55 PM
well im at this resurrection's final stages, it started up on an evo8 base tune last weekend but wouldn't idle long. log showed a bad o2(wiring). new o2 ordered, wiring is getting sorted. i also got a knock sensor dtc, replaced the sensor and cleared the code. and lastly i unpluged the evo8 maf and it ran fine!! for a few secs then it starts idle surging.
there's a way to lock the car in closed loop, but im not familiar with v3. i got an sd kit and p&p harness from ecmlink i picked up a while back and decided, i don't need no stinking maf, so a good buddy will be here sunday to tune in speed density. till then i'll sort out all its issues.
G
(JDM Unit)
04/11/13 09:34 PM
Looks good! I wouldn't run that crank pulley though. Will end up doing more harm than good. Also I would invest in some exhaust wrap for the downpipe and exhaust mani. As well as some reflective material for that upper cold side output next to the exhaust mani.
ade
04/12/13 05:06 PM
crank pulley came with the car, are there horror stories to running it?
yeah i picked up some reflective material for the piping but wrapping the manifold and downpipe... taking it off.... then putting it back on.... sigh
ade
04/20/13 05:30 PM
started the car in sd. but o2 has a mind of its own
do i have this right?
looking into sensor plug with knob tab or guide at 12oclock
top left - blue >to> white -shielded on engine harness
top right - white >to> black -shielded on engine harness (continuity to ecu)
bottom left - black >to> red on engine harness (12volts recorded)
bottom right - black >to> black on engine harness (continuity to chassis ground)
engine harness on the left ------ o2 sensor on the right
Number996
(Member)
04/22/13 04:28 PM
hey ade,
I don't know if anybody's said anything about that plug coming off the ecu harness but if it's anything like mine (and it looks exactly the same) a previous owner had tapped into the front o2 wire for one reason or another and the green wire/white male plug was just hanging there. I found mine when wiring an AFR gauge to my ecu and deleted it.
ade
04/26/13 08:06 AM
does it plug in somewhere?
Quoting transparentdsm:
i assumed it just dangled under there like ^ said
04/26/13 08:31 AM
you can plug it into a aftermarket narrowband gauge, but that is all. its just a o2 voltage output. let it dangle or tuck it into the wires or add yourself a narrowband gauge.
edit: if your still troubled with the o2 wiring and no one helps you by sunday i will take pictures of my o2 and wiring harness, if you did everything right according to a manual the only thing i can think of is the two black wires are backwards..
04/26/13 08:35 AM
Quoting Number996:
hey ade,
oh man, you cut the wire you should have plugged the gauge into. haha its a simple tap in and its supposed to be there so when your check engine light comes on for a bad o2 you can attach a multimeter there and see if its dead. i mean you have the gauge now so you'll def know if its dead, but thats what the wire/plug was there for. also no previous owner installed it, thats how it comes from the factory, mine has it to and so does every other VR4 and DSM.
04/26/13 09:00 AM
Quoting ade:
did he help get the squirrel infestation out??? i just recently saved a cat that fell 30 feet from a tree
also what number is your car??
ade
04/27/13 08:56 AM
Jack the cat, got hit by a car the day before the storm sandy arrived, everybody on my canal were like chickens without heads and no one fessed up about doing it. he was a gnarly cat and an awesome wing man, i cant tell you how many times he went on his sat morning walk and came back an hour or two later in the arms of some swexy(sweaty sexy) jogger. we miss him dearly.
1052/2000
ade
05/26/13 02:35 PM
took it out two weeks ago for a spin after an extensive tuning session. shifter csbles need adjusting, air leak at vband before wideband made readings inaccurate. Since then ive sealed the vband and moved wb sensor to o2 housing. waiting on swaybar brackets from jnz.
oh and yes i am.. we were both giggling like school girls. check out the cam mans other vids, hes got a supercharged lotus elise.
enjoi
ade
06/01/13 02:39 AM
lots ov work getting done. evo8 suspension is next.
06/01/13 07:00 AM
car looks great, sounds great and seems to be doing pretty great huh? glad to see it on the road.
ade
06/01/13 01:26 PM
thanks.
i decided to go closed loop with the catch can. i need to order a few bits from summit and do a bit of welding. here is a mock up of things to come.
bit by bit
ade
06/09/13 12:37 AM
keep practicing
need to reinstall the valve cover baffle and put together a bracket for the can
ill get to these soon
(Senior Member)
06/12/13 08:44 AM
Nice job with the valve cover. Bet it out flows my 1/4" npt taped cover. Want to weld some ports on mine too? I didn't realize Paumanok, NY was on long Island. As wide spread as this board is were practically neighbors.
I've been posting wanted ads on craig's list for evo struts around here. All I came up with was an evo 9 fuel pump. Nice find on those Blistines.
What are you tuning with? Ive been playing with my ostrich a bit lately. There's some real fancy SD stuff posted from all over the world over on dsmecu.com.
Lot of good work here Keep it up.
ade
06/12/13 04:43 PM
Hello neighbor, Paumanok was what long island was called before we all arrived. if u dont mind the not having the cleanest welds yeah sure ill git er done.
i did luck out on the bilsteins, will evo8 kyb's be sufficient? i can put you in touch with a fellow board member who has a set up for sale pretty cheap.
i am tuning with ecmlink's v3, its simple to learn, no complaints so far. ostrich was an option, but ive heard its really involved and time consuming.
thanks for the kind words and the link, i registered, just waiting on an activation email then im in there like swim wear.
ade
06/13/13 06:09 AM
i had to move the galant to the street from the garage, it had rained so bad the creek that runs on the property flooded and came about two inches up into the garage.
yesterday i go to start and pull it back into the garage, no spark. unbolt the cas, spin it, nothing!?! ecmlink wont even link up to the ecu. the cel and turbo gauge don't light up.. my ecu needs to go on a lil trip.
why did this happen? could it be because it wasn't bolted to the body? any 1 have any ideas?
(Senior Member)
06/13/13 10:12 AM
It sounded like Some Upstatie town. Learn something new every day.
I've only fried ecu's to non stock o2 sensors, bad ISC stepper motors or leaking capacitors.
Is it the best thing for it? No, but I haven't had an ecu bolted down since 2004
Open the cover and see if you notice any burning or discoloration. Sometimes its very localized and you can clean traces, swap components and be up and running.
ade
06/13/13 11:07 AM
i did have an issue with my o2 sensor, replaced, rewired and thought it had been resolved, ill look through it all once more to make sure. i dont have a spare ecu around to test, ill check and make sure power is gettimg to the ecu. i dont think the problem is the ecu, its clean no leaks or burnt tracers.
(Senior Member)
06/15/13 09:26 AM
I have a couple spares if you just want to see if it starts.
Also you said in my thread, if it was you, you would tack the screw to the baffle. You did all that work to the valve cover and didn't remove the baffling or you just left it out?
ade
06/15/13 04:13 PM
i tried building the aluminum up and around each hole, it worked, but what a mess! i took it apart and ordered compworks alu baffle.
u have pm
Zee
(Member)
06/20/13 06:11 PM
hey man this is zee i was talking to you earlier i should have looked here on the forums after i got back from the army to take it to some reputable shop
NOTE TO EVERY ONE
top level performance = scammmers
ade
06/25/13 10:37 AM
whats up Zee, just thinking of the amount of money you threw at them and what you got back in return makes me queezy.
ade
06/28/13 06:00 PM
well a few weeks ago after a rainy week the car would not start. i enlisted the help of Toybreaker and Tektic in contacting the galant spirits and eventually figured out i had a scrambled ecu. im not sure if its burnt ground tracers or leaky crap but me thinks it was cause i wired the a/f logger into the ecu incorrectly, either way im paying for it. so off to ecmlink it went.
but as usual i got impatient...
so i picked up an eprom ecu, it had slightly leaky caps but was clean and most importantly, was a known working ecu.
a few minutes on our grand inter-webs and i found and ordered these.
splitmotorsport cap kit & eprom socket
then visited radioshack for their $14 desoldering iron
got rid of the leaky caps
this was the tricky part, but it got done
eprom out....
socket in
i gotta wash the board with soap n water, let er dry, then solder in the new stuff. i thought the ecu would catch ablaze on me while de-soldering , but it turned out to be a cake walk.
i cant wait to have a running galant again.
(Senior Member)
06/28/13 09:19 PM
I don't think soap and water is a good idea. Dw-40 was made to clean electronics. Try that or rubbing alcohol if your trying to take the waxy coating off. I'm likeing the desoldering iron. I'm going to have to get me one of those.
ade
06/30/13 01:50 PM
John you are welcome to the desoldering iron whenever u need it. i did wash the board with soap and water, let it dry and it came out fine. i soldered in the eprom socket and caps, plugged it in and success! wooooot!!!
ade
07/03/13 10:26 AM
catch can, oem rear motor mount and lc-1 installed
ade
07/09/13 09:45 AM
a mad scientist constructed a device that will have my stock in dash fuel gauge read my gm fuel level sender
ade
07/11/13 06:48 PM
ive got my work cut out for me
i aint scared
(Senior Member)
07/12/13 07:04 PM
Fix the leak and put it back on. Build the LSD rear into my subframe with welded trailing arms.
Zee
(Member)
07/14/13 07:53 PM
sent u pm man hit me up
ade
08/04/13 02:26 PM
thanks to john(tektic) for all his parts and all his hands on help yesterday.
afco upper ca
turned down the rod end spacers to fit snug
lsd in
thanks to John(jmelocik) for the teins, bilstiens and those sweet adapters
eliminating trailing arm flex
getting there
ade
08/11/13 01:44 PM
threw the plates on..
and went for a spin lest night...
few thing to button up the next few days. i took a week off starting this wed. i just might make mod this upcoming weekend!?!
08/11/13 02:29 PM
car is coming along great. looks real good.
ercp98
(perpetual n00b)
08/11/13 05:15 PM
can you provide more info on the rear shock adapters?
another alternative to welding.
faqinshiet
(Member +)
08/11/13 05:27 PM
Info on afco upper ca
ade
08/13/13 01:03 PM
thanks, ive been driving it the last few days and loving it. few things i need to button up and ill be happy with her.
Quoting ercp98:
i got them from jmelocik give him a shout, i cant rem where he got em from.
Quoting faqinshiet:
i got these for the rod ends, packed em with grease
ade
08/24/13 09:21 PM
cant take the fumes getting into the car, started putting floor plates in.
That danm crescent wrench is so handy
ghostinthevr4
(Likes Poetry)
08/27/13 06:25 PM
Great work your going hard on that VR4 you make it look simple but it's not. Nonthing worth having comes easy anyways. Can you give us a contact to that John guy? I want those bilstein apapters I have some and don't want the down time of the weld job. What forum is John so I can send him a P.M.
DynastyLCD
(Dissapointing Member)
08/28/13 03:00 PM
John is on this forum if i remember right.
would be awesome if we could get a group buy on these... i think the welding is the one part of the evo suspension swap that's holding me back from actually doing it.
ghostinthevr4
(Likes Poetry)
08/29/13 02:19 PM
He's on this forum very nice. Come on John it's group buy time or you can just make one set for me.
My KYB's are going bad I got Bilstien's waiting for my Galant. Sorry for the thread jack Ade.
09/16/13 08:59 PM
Yeah, i want some adapters as well.
ade
01/24/14 12:37 PM
i had no idea where the adapters came fro till a few days ago heres a link to a thread started on the subject for any future seekers. link
The cars been on the road for a few months now, with the weather being so crappy and the limited time i have nowadays its been tough getting to the little issues the car has. i still need to work on my tune, seal up the trunk, find and install a fuel swirl pot(im looking at versions that encloses the pump to keep the noise down), replace the pass side axle seal,re shim my rear end, rebuild my drive shaft, buy and install fans to replace the old worn out fans and a few odds and ends like a sound system, interior and exterior details.
I had an issue with my clutch not disengaging properly and after pulling the trans to shim the pivot ball, playing with the cables and replacing both clutch master and slave, i found out it was my pedal set. took it out welded it the third time around and installed and no more issues . it def took its toll as my 1st and 3rd syncro's took a beating. i see a trans rebuild in my future.
Thats all for now.
ghostinthevr4
(Likes Poetry)
01/24/14 01:57 PM
I'm glad to hear you got her running, you put a lot of work in her.
(Senior Member)
01/24/14 06:29 PM
What he didn't mention was he started to take it out new years day at 9:30 at night in his driveway during a blizzard.
ade
01/27/14 12:47 PM
go hard or go home
ade
02/07/14 09:37 AM
So a few days ago, I noticed my heater blower motor stayed on after turning off the car and removing the keys out of the ignition, I turned the blower off, problem solved for now. Two days ago I came back to a dead battery, this time the blower shut off after turning off the car but turned on a few mins after I had left.
Has anyone encountered this in the past? I have a feeling its a ground issue. I can't read my speed sensor through ecmlink and was wondering if they were on the same ground track. Either way I have a feeling I'll have to pull my dash in order to fix this. Damn squirrels must have trashed the place during their stay.
I'll appreciate any insight on the issue, thanks in advance.
ade
06/01/14 09:32 AM
Edit: Ended up not using these. with the wide option i could not get the drivers side seat centered without modifying the center console.
ade
06/01/14 09:34 AM
my buddy really dug em
boostback
(Junior Member)
06/01/14 11:31 AM
very nice work
ade
06/03/14 07:24 PM
They are not installed, that was just a mock up. Getting that drivers seat centered and low is gonna be a painful process.
92_talon_awd
(Member +)
06/03/14 08:46 PM
I dig those Corbeaus man. Had a set in my 2g, some of the most comfortable seats I've ever had. I'd like to get a set in the Galant one of these days.
ade
07/01/14 04:34 PM
I got rid of the seats, corbeau's wide option. imo, is not an option for the galant.
I also had the car for sale but i couldn't get my asking price. so i now rent a garage.
I want her back on the road asap so she will be seeing alot of lift time for the below in the next few weeks.
complete drive shaft rebuild
rear end needs to get re shimmed
need a solution for the 044 pump noise
pass rear axle needs a new boot
replace cracked valve cover
the brake booster needs its own vacuum source
throttle body rebuild then another boost leak test
fix power steering rack leak
tune on the street
fine tune on a dyno
ade
07/22/14 05:28 AM
i've ordered the drive shaft rebuild kit from jnz and the rear differential shims from a local mitsu dealer, now working on a solution for the 044 pump.
At levels below a 1/4 tank, the noise the 044 makes scrounging for fuel gives me the willies, which of course brings up the possibility of blowing up the motor due to a drop in fuel pressure.
so i looked into surge tanks/swirl pots.
i wanted something like the above but while this help's with my starvation issue, it does nothing for the noise.
so i did a little more digging and found the below.
intergrated engineering submerged 044 billet surge tank
034 motorsport fully enclosed fp34 044 fuel surge tank
now a normal swirl pot/surge tank is fed by an intank fuel pump but this isn't an option in my case so i'll have to go with a hunch and mount the pot lower than my fuel tank which in theory should keep it filled up. that being said i'm leaning towards the 034 unit's fully enclosed and compact design.
(A hole)
07/22/14 10:22 AM
It seems to me that it would be a lot cheaper and easier to swap to an in-tank Walbro equivalent or something. They aren't quiet, but aren't deafening either. Why don't you just ditch the 044 all together? Unless you are planning to do serious track outings in the future, a swirl pot is pretty overboard. I've only really seen them used in road course/rally cars to keep from fuel starvation during continuous hard cornering. I've also seen them used in a lot of off road rigs, like rock crawlers, which operate at ridiculous angles. Guessing you won't be doing any rock crawling with the VR4 though.
I'm glad you kept the car. I was watching this on Ebay and thought it sold for around 4k?
ade
07/22/14 05:39 PM
i fell overboard the day i decided to get a gvr4
this is what im working with buddy
(A hole)
07/22/14 06:03 PM
That looks nice for a track car or garage queen, but if you plan on driving the car I'm not sure that's a great setup. I'm sure you have your reasons, I just think judging by what you're saying about the noise, you won't ever be able to bring it down to a manageable level.
There's 2 issues with that setup that make it less than ideal for a street car IMO; the first being external fuel pumps by nature are loud. The fuel tank and the liquid within do a lot to muffle the noise. Without them, you would need to insulate the pump somehow to isolate the noise, and I just don't see how that would be possible with the pump in its current location.
The second issue is your entire setup is exposed to the elements, and is in a prime location to get shit on by any and everything you drive through. If you plan on ever driving this in the NY winters, those components and electrical connections will need to be extremely weather proofed in order to stay looking pretty and functioning. I think that's the last place I would locate the pump on a street car.
I'm not really sure what your goals for the car are, though. If you're building a weekend toy for the track or something, nothing I said really matters. I just assumed you intended this thing to be fairly streetable when you mentioned the pump noise being annoying. Track cars are pretty much expected to be void of any creature comforts.
coyotes
(Hipster VR4)
07/22/14 07:19 PM
looks cool though
ade
07/22/14 09:08 PM
thanks guys, its my cool car, it is my track car, my drag car, my street car, my garage queen, my jsballer. i picked it up, knew what i wanted and been building ever since.
your first issue with my setup is my third, external pumps are loud. thats just part of the point to the surge tank. it'll keep the pump submerged, muffle the noise and move the pumps location.
your second issue is further down the line in my issue queue, mostly because exposure to the element hasn't been much of an issue, i drove it daily all winter through brooklyn, queens, long island and manhattan without one breakdown. i have access to a lift and regularly cleaned and inspected my under carriage keeping my electrical connections and components pretty and functioning.
anyway i had planned on making an under panel for the rear but it wasn't gonna happen thanks to the fuel pump location. now that its getting relocated, i can plan on getting it made.
as for my goals, like everyone i want a reliable galant vr4.
ade
07/24/14 09:46 PM
Quoting GSTwithPSI:
yeah it did, but the force is strong between me and this car.
got my drive shaft rebuild kit in from jnz, watching jafromobile driveshaft rebuild videos. gonna try and get this done tomorrow.
ade
07/28/14 12:27 AM
so far so good
ade
08/06/14 10:30 PM
finally got to the drive shaft earlier today, i couldn't find a 2 arm puller big enough to get under a bottom socket.
the rear differential flange union joint was a bitch, it only turned on one axis, took 30 min to get through this.
smh these were in bad shape
all done
thanks to Jafro's video, for making this a walk in the park.
next: shimming the rear diff (wish there was a walk through for this)
ade
08/08/14 07:39 AM
both rear axles cleaned up and re-greased, one torn boot replaced
put a few coats on the ds
waiting on a few parts for the rear diff rebuild
coyotes
(Hipster VR4)
08/08/14 11:18 AM
looks good, I know I have to do mine at some point, gettin that decel noise everyone has.
JamesFoster
08/08/14 06:40 PM
What did you coat it with?
(A hole)
08/08/14 10:03 PM
Good work. Make sure when you put new grease in the axle, you only add a little bit. If you add too much, it will come flying out as soon as the car gets up to speed. Try and get the clamp on the boot super tight too. Everything is looking great though. It's nice to see people doing things to make their cars dependable.
ade
08/08/14 10:51 PM
i did put too much grease in the axles, a tech informed me just before i put them back together
Quoting JamesFoster:
0ne can of flat black rust-oleum engine enamel
ade
08/20/14 06:00 PM
swapped out my bad speed censor for a good one yesterday, drive shaft is back in and ill finish up the rear diff before the weekend
figured out why i cant get my idle to stick. new used isc on its way
fp1's will go in this weekend, then i work on welding -an fittings to the new valve cover and touching up a leak on the cold pipe.
ade
08/26/14 03:22 PM
the diffs back on, after checking it myself then sending it out to get double checked, turns out its within spec. waiting on my fav local parts store for a front axle and shockproof. got the fp1's in yesterday, next will be new re-gaped plugs, installing pass side front axle, cleaning grease off the exhaust and once i get hands on my new old isc, set base timing, tps, idle swith & biss.
ade
08/30/14 06:32 PM
1052 is on the ground, cams are in, i lucked out and found a beam torque wrench that went lower than 20 foot pounds for the cam caps, new plugs are in. i also cleaned and painted the exhaust from the mid pipe down with black high temp rattle. isc came in from 89Mirageman, thanks man.
its out with me in queens for the weekend for some logging. i like what the 264's do, while cruising(which is all i'm doing) motor feels like it added on a few more cc's. im gonna start tuning with Stacy(my1gdsm) in a few days.
08/31/14 08:25 AM
very nice, glad to read things are going in your favor. let me know how things go with stacy i have been talking with him and im thinking of having him do my car as well once i get my 264's, or i decide to put the 272's i have in.
Generated in 0.024 seconds in which 0.014 seconds were spent on a total of 4 queries. Turbo powered.
