**DONOTDELETE**
(Unregistered)
04/01/05 09:30 AM
Intrepid COP setup!!!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=33689&item=7964632790
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=33689&item=7964633192
If anyone is thinking about doing the coil on plug setup, this would be the place and time to buy them. 250.00 is a great deal. Just in parts now, I have over 200.00 and I still haven't made my plate. The only thing I don't get is why one of the setups is 250.00 and the other is 500.00. Does anyone have a clear answer for this?
I forgot to say, Tym Switzer is selling them so you know you get a quality setup!
(Turn Right Racing)
04/01/05 09:35 AM
Re: COP setup!!!
I'd say he's testing the market. Better get one of the $249 while they last!
**DONOTDELETE**
(Unregistered)
04/01/05 09:36 AM
Re: COP setup!!!
That is for sure, dirt cheap. Like I said I am making my own and I will have that much in parts alone.
14u2nV
(Resident Pedobear)
04/01/05 09:37 AM
Re: COP setup!!!
I think I can mass produce these, for around $200/each, including coils, plate, plugs, and quality cardboard packaging. Mine are made of 1/4" alum. also.
**DONOTDELETE**
(Unregistered)
04/01/05 09:38 AM
Re: COP setup!!!
Is that with the 2.7 coil or the 3.5 coil?
14u2nV
(Resident Pedobear)
04/01/05 09:39 AM
Re: COP setup!!!
2.7 right now,,, 3's will be around $250 approx.
**DONOTDELETE**
(Unregistered)
04/01/05 09:40 AM
Re: COP setup!!!
The connectors alone are 50.00
14u2nV
(Resident Pedobear)
04/01/05 09:41 AM
Re: COP setup!!!
ohhhh, no sir,,,, I might be able to get them for $5 each,,, if not, I have a way to make my own that work great.
**DONOTDELETE**
(Unregistered)
04/01/05 09:42 AM
Re: COP setup!!!
The connectors them selves are around 5.00 but the splice wires are another 3 or 4.00 each.
14u2nV
(Resident Pedobear)
04/01/05 09:43 AM
Re: COP setup!!!
ye with little faith.
**DONOTDELETE**
(Unregistered)
04/01/05 09:44 AM
Re: COP setup!!!
Damn you. I just wasted more money. Are they new or used?
14u2nV
(Resident Pedobear)
04/01/05 09:46 AM
Re: COP setup!!!
I find out today if the "new" ones will work (~$5ea). If I make my own, They will of course be new as well.
**DONOTDELETE**
(Unregistered)
04/01/05 09:49 AM
Re: COP setup!!!
Can you tell what kind of coils Tym is using 2.7 or 3.5?
14u2nV
(Resident Pedobear)
04/01/05 09:55 AM
Re: COP setup!!!
I think the only difference is that a 2.7 uses a spring, and a 3.5 uses a rod. Also,, my 2.7's have the two mounting holes oposite each other, not one on one side, and the other on the end. Other than that, they look identical. I don't imagine there is much difference in performance for one over the other. Maybe someone else who knows can chime in. Also, I've read that the springs can be removed and replaced with a copper or aluminum rod, which would make it the same thing.
**DONOTDELETE**
(Unregistered)
04/01/05 09:57 AM
Re: COP setup!!!
I really would like to know why there are 2 different prices for apparently the same thing as well?!? AEM is coming out with the CDI and individual coils as well. You still need to use wires and plugs but other than that, it still seems to be a nice set up.
Gabor
(Decal Specialist!)
04/01/05 10:14 AM
Re: COP setup!!!
Called him to verify.
The price is $249.00 He doesn't know why the $499 item is still up there. That was the old price. He don't want to say which coils he use 2.7 or 3.5
He's affraid people will copy it.
**DONOTDELETE**
(Unregistered)
04/01/05 11:47 AM
Re: COP setup!!!
why cant you use 4cyl galant coils on 99 and newer
(Turn Right Racing)
04/01/05 11:54 AM
Re: COP setup!!!
Good question, as Mitsu has many cop applications now. I'm going to look into that.
**DONOTDELETE**
(Unregistered)
04/01/05 12:00 PM
Re: COP setup!!!
definitiely a cool idea and when I get my galant I may get those, just for ease of install and cleanliness, but looking at the pic on ebay, the aluminum was cut horribly. If you look closer on the right side, it's all jagged and none of the holes are even drilled straight...pretty half ass to me.
I'll look somewhere else for a COP
geoff
DarkDevilMMM
(if I want a potential headache, I rather just get another GVR4)
04/01/05 12:02 PM
Re: COP setup!!!
is COP setup really worth it? I mean for $250 I am get a lot of fun out of something else....
**DONOTDELETE**
(Unregistered)
04/01/05 12:06 PM
Re: COP setup!!!
it's probably worth it if you have the msd ignition or aem system, but other than that, I don't see how it can be better...
My buddy made his for dirt cheap a lot less than 250...pretty sure it was about 75 all together...he used coil packs out of a chrysler 300m. It looked cool and worked with his msd ignition, but he said he couldn't notcie any difference just from driving it daily, plus his rubbed up against his hood...
geoff
**DONOTDELETE**
(Unregistered)
04/01/05 12:07 PM
Re: COP setup!!!
If you are dumping in alot of fuel and spraying nitrous you don't want your spark to blow out. So I would have to say yes, it is worth it!! Read in the how to article on curtis's setup. He said it was worth every bit of it.
14u2nV
(Resident Pedobear)
04/01/05 12:08 PM
Re: COP setup!!!
You could build one for around $50, if you wanted to use used parts, and cut your own plate with a saw or something. I get to cut them on a laser, so mine are pretty.
steveGalant VR4.org Administrator
(Assmilk Pearl)
04/01/05 12:13 PM
Re: COP setup!!!
Spoken like a true DSM'er (GVR4'errerrer?)
**DONOTDELETE**
(Unregistered)
04/01/05 01:45 PM
Re: COP setup!!!
If I could get a list of Mitsu part numbers I bet I could get the whole setup cheaper then $200.
25% of list prices helps
The 99-03 Diamante's have 3.5Lmotors do they use coil on Plug? I'll have to look at my sister's ride and check.
14u2nV
(Resident Pedobear)
04/01/05 02:04 PM
Re: COP setup!!!
Mitsu coil overs are bigger and high dollar from what I see.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7964758658&category=33689
**DONOTDELETE**
(Unregistered)
04/05/05 08:55 AM
Re: COP setup!!!
Some very good info on the intrepid COP setup. Part numbers and everything.
http://www.galantvr4.org/ubbthreads/showflat.php?Cat==&Board=UBB1&Number=198878&page=0&view=collapsed&sb=5&o=31&fpart=1
**DONOTDELETE**
(Unregistered)
04/05/05 08:59 AM
Re: COP setup!!!
One thing I need to know is what wire is which. The splice wires that I got from toyota are black with no colors. There are numbers 1 and 2 on the connectors if anyone can help I would apperciate it. Thanks, Chris
**DONOTDELETE**
(Unregistered)
04/05/05 09:10 AM
Re: COP setup!!!
Does it even matter what wires are which on the coil?
boostx
(On The Wrong Side. )
04/06/05 12:59 PM
Re: COP setup!!!
the fun has started
i need coils now
so what you think
**DONOTDELETE**
(Unregistered)
04/06/05 06:22 PM
Re: COP setup!!! *DELETED*
Post deleted by 645
**DONOTDELETE**
(Unregistered)
04/06/05 07:23 PM
Re: COP setup!!!
looks nice but I personally wouldnt bother with that COP stuff. The only standalone I run is Electromotive, which includes the coils, and Ive seen the stock coil packs support 500 wheel nicely.
(Space Blanket from NASA plumbed into the attic)
04/06/05 08:19 PM
Re: COP setup!!!
You need a ride in a car before and after. They work.
It's not always about top end HP but drivability, thats where they really perform, HP and torque both go up but the off idle is crisp and the part throttle to passing on the street pulls way better.
Keep up the good work John you'll love it.
**DONOTDELETE**
(Unregistered)
04/06/05 08:24 PM
Re: COP setup!!!
If you're going to go COP why not use motorcycle coils? Lots of the AEM guys do it.
http://forum.aempower.com/bbs/viewtopic.php?t=7141
**DONOTDELETE**
(Unregistered)
04/06/05 08:28 PM
Re: COP setup!!!
mitsu has COP on it's 04 galant mivec motor has a two wire set up
14u2nV
(Resident Pedobear)
04/06/05 08:34 PM
Re: COP setup!!!
Yes, you've said that twice. Check the price,,,,, bet it's hella expensive, and your not likely to find one in a junk yard.
**DONOTDELETE**
(Unregistered)
04/06/05 09:09 PM
Re: COP setup!!!
I will check tomarrow on price on COP my cost or your cost
14u2nV
(Resident Pedobear)
04/06/05 10:37 PM
Re: COP setup!!!
Even at your cost, I bet it won't beat the $50-$200 it takes to make your own.
**DONOTDELETE**
(Unregistered)
04/07/05 12:17 AM
Re: COP setup!!!
throttle response is what i'm after. 4g63 response is on the slow side....
**DONOTDELETE**
(Unregistered)
04/07/05 09:12 AM
Re: COP setup!!!
**DONOTDELETE**
(Unregistered)
04/07/05 09:17 AM
Re: COP setup!!!
I finished it last night, just wanted to share some pics with you guys. Thanks, Curtis for your info on the subject. The pic of the fuel system is for my nitrous only, thats why its so small. Wanted to share that pic too.
HertzGalant VR4.org Administrator
(OneTitle to rule them all.)
04/07/05 10:14 AM
Re: COP setup!!!
boostx
04/07/05 10:17 AM
Re: COP setup!!!
hey BOOSTIN HARD do you want to finish mine
**DONOTDELETE**
(Unregistered)
04/07/05 10:50 AM
Re: COP setup!!!
Just take your time and it will turn out just as nice as mine. I got my rubber grommets at ace hardware.
14u2nV
(Resident Pedobear)
04/07/05 10:51 AM
Re: COP setup!!!
What is your plate made of? how thick, how did you cut it? Mine is 1/4" alum, cut by our laser.
**DONOTDELETE**
(Unregistered)
04/07/05 10:56 AM
Re: COP setup!!!
Mine is .080 aluminum cut out by my jig saw.
14u2nV
(Resident Pedobear)
04/07/05 11:05 AM
Re: COP setup!!!
bet that was fun.
**DONOTDELETE**
(Unregistered)
04/07/05 11:14 AM
Re: COP setup!!!
Not so bad. You just have to have a steady hand.
**DONOTDELETE**
(Unregistered)
04/07/05 05:10 PM
Re: COP setup!!!
my cost on the coils where $70.oo each thats not all bad and that is for the 04 galant
mivec motor COPS and they are smaller coil pack then on boostin hard and also it would
be easier to hook up to the harness
04/07/05 09:11 PM
Re: COP setup!!!
I've created a bunch of fabricators. Muhahahahahahahaha
14u2nV
(Resident Pedobear)
04/07/05 09:21 PM
Re: COP setup!!!
NOT BAD????? compared to the $20-$35 ea were paying for the other ones, that is real bad. I doubt their much easier to hook up either, since theyve had 12 years worth of redesigns on their electronics. NOt dissing you, just making a point.
14u2nV
(Resident Pedobear)
04/19/05 07:43 AM
Re: COP setup!!!
Anyone got a coil they could lend me that has the bolt holes on the side and end, for a couple days??? Mine has the holes opposite each other, and I want to make my plates with both. Here is another awesome drawing:
boostx
04/23/05 08:45 PM
Re: COP setup!!!
i found this
**DONOTDELETE**
(Unregistered)
04/23/05 11:36 PM
Re: COP setup!!!
wonder how long that plexiglass would hold up to the heat.
boostx
04/24/05 07:07 AM
Re: COP setup!!!
i was thing the something but i fell its a template
**DONOTDELETE**
(Unregistered)
04/24/05 07:22 PM
Re: COP setup!!!
HUH?
Put down the glass, and step away from the bar!
**DONOTDELETE**
(Unregistered)
04/25/05 07:30 AM
Re: COP setup!!!
04/25/05 07:37 AM
Re: COP setup!!!
Lexan would be way cool and would stand up to the heat, but theres no room for error it would have to be perfectly cut or it would look like poop. I looked in my plastics handbook and can't remember the engineering name for lexan to find its melting point. I'll see if I can find it.
3Diamond
(Hampster Powered and In the "Private" clan !)
04/25/05 12:32 PM
Re: COP setup!!!
Careful, even 110 degrees is enough to slooowly deform sone of them. They do sell better ones, but they used to cost a looot
Generated in 0.014 seconds in which 0.011 seconds were spent on a total of 4 queries. Turbo powered.
