Kibby
(Member)
03/10/18 09:30 AM
What exactly is the material on the exterior roof?
Its like a thick material??? Anyways i haven't been on in quite awhile. Car is still jsb and outside forces have kept me from getting the car running again. I do however want to keep/slow things down from getting worse. Just wanted to know the best route to go. Thanks
(Senior Member)
03/10/18 06:50 PM
Re: What exactly is the material on the exterior roof?
Paint?
kumfasa
(Member)
03/13/18 04:37 PM
^ Yep, Paint on mine too.
Kibby
(Member)
03/13/18 06:21 PM
So just a really thick coat of paint? The stuff chipping off is like 1/16" thick, probably thicker.
holeshotmoe
(subclass marmoreus)
03/13/18 08:24 PM
Maybe you're seeing the clear coat peeling?
FlyingEagle
(Eager Beaver)
03/13/18 10:22 PM
Quoting Kibby:
Pics??
Sounds like plastic body filler, if it is anything other than a "skin" film coming off the paint.
kumfasa
(Member)
03/14/18 02:19 PM
Maybe someone repaired some hail damage, and it is body filler your seeing?
(Hard Snarker)
03/14/18 05:24 PM
Yeah, itís just steel with primer, base coat, and clear. If youíre seeing anything else it would have to be shoddy repair work unfortunately.
Kibby
(Member)
03/15/18 04:26 PM
This is whats going on. About 6 inches to the left of this is the windshield
(I ain't no puny human)
03/15/18 05:49 PM
That is a cracked and broken skim coat on the roof. My son has the same on 100/2000. Looked perfect until the PO got mad and dented the roof. Big piece broke off.
Vince
(Junior Member)
03/15/18 11:02 PM
That simply is not right........ Maybe someone filled in a missing sunroof?
kumfasa
(Member)
03/16/18 02:13 AM
^ Yep, hail or maybe sunroof removal. Regardless someone has filled it for some reason and now itís no good.
Kibby
(Member)
03/23/18 12:32 PM
Quoting thomcasey:
So best route would be remove it all, do the por fix, apply a new skim coat and paint?
(Turn Right Racing)
03/23/18 12:56 PM
You don't really need POR if that is what you are suggesting. You will likely need some serious dent removal before removing any rust and priming/painting properly.
Generated in 0.003 seconds in which 0.002 seconds were spent on a total of 4 queries. Turbo powered.
