Mn92gvr4
(Member)
10/31/15 12:48 PM
936/1000 progress report
Hello everyone. haven't had the time to write one of these up until now. I have owned 936 for about 2 years now. When I bought here she was basically bone stock with a rebuilt bottom end from DSMGraveyard. she has some rust issues that I plan on fixing this spring, (no room in the garage thanks to my brothers TA).
Driveway Queen lol.
Anyway here is how she currently sits.
I would like to see close to 500 horse. I will be switching over to a borg warner s300 turbo soon.
if you see any weak links or have any advice let me know. thanks for looking
Engine- bottom end.
-evo 9 pistons
-dsm graveyard blueprint rods
-evo 9 oil squirters
-stock crank
-cometic mls headgasket
Engine- Head
-mild port on the exhaust side.
-crower 272 cams
-crower single springs w/chromoly retainers
-gsc zero-tick lifters. (they do tick btw)
-BC stainless steal valves
-ferea valve guides and seals
-fidanza cam gears
-hks fine tune belt
Intake
-jmf street intake manifold
-s90 70mm Tb
-ebay intercooler w/short route piping
Exhaust/turbo
-ebay tubular manifold. (its leaving soon)
-stock 16g turbo
-3" DP & exhaust
Fuel/spark
-E85
-FIC 1120 low z injectors
-Fic high flow rail
-255 inline fuel pump
-fuel lab filter
-16g fuel cell
-braided ss lines
-spark tech cop
-ngk br8es
Cooling
-griffin sirocco radiator
-1g upper thermo housing
-si slim fan
Electronics
-odessey pc680
-innovate mtl-x wideband
-glowshift gauges
-boost
-water temp
-oil press
-oil temp
-fuel press
-DSMlink v3
Drivetrain
-act 2900 pressure plate
-act 2900 4puck sprung clutch
-fidanza aluminum flywheel
-trans and difs stock, for now
KiNgMaRtY
(Member +++)
11/02/15 10:17 AM
Re: 936/1000 progress report
I like the placement of your radiator. Seems thick and like it fit well right behind the intercooler
Mn92gvr4
(Member)
11/02/15 12:19 PM
Thanks. It took some finess but it works well.
Mn92gvr4
(Member)
11/05/15 05:35 PM
Anybody know if the drivers seat back and the passenger seat back are interchangeable? the only difference I see is the lumbar adjustment.
(Senior Member)
11/05/15 08:06 PM
Quoting Mn92gvr4:
Engine- bottom end.
-evo 9 pistons and rods
100% sure you don't have evo 9 rods on a stock 6 bolt crank.
Engine bay looks great though! I wanted to install my intercooler in the same spot You made it work much better though.
Mn92gvr4
(Member)
11/05/15 09:10 PM
ok. you caught me. the po said it was a dsm graveyard with 9 rods and pistons. just checked their website and its only the pistons. my bad.
thanks the install turned out to be rather simple just attached the upper bracket to the bumper mounts and welded some tabs to the radiator support.
(I ain't no puny human)
11/06/15 08:59 AM
Quoting Mn92gvr4:
The seat backs are shaped differently (Larger bolster on the outside of them), also the gear/teeth for the recliner would be on the wrong side.
Mn92gvr4
(Member)
11/06/15 12:12 PM
Ah. Ok, they looked similar. Forgot about the gears
Mn92gvr4
(Member)
11/24/15 08:12 PM
Couple of new additions. Got the head redone after a couple of bent valves. Added a jm fab intake and fic fuel rail.
Mn92gvr4
(Member)
11/25/15 08:25 PM
Custom fuel rail brackets.
Mn92gvr4
(Member)
12/20/15 05:25 PM
Got her back together after the valve job. Purred like a demented kitten
Mn92gvr4
(Member)
01/02/16 04:17 PM
Just got my floor mats. Big thanks to turboflanagan. They look awesome!
Mn92gvr4
(Member)
01/04/16 08:55 PM
ok. I believe I have my winter plans laid out.
1. fix the dsmgraveyard bottom end with new rods. I see a lot of people using pauter x beams or manley turbo tuff rods. also considering carillo I beams. any imput one rods would be a big help.
2. kiggly main girdle.
3. borg warner s300 turbo (still working out what specs I need to fit my needs).
4. top-mount exhaust manifold
5. acr2 spark amp
6. finish shaving the bay and minimizing wires
I am looking for 5-600hp plus. any and all input appreciated
Mn92gvr4
(Member)
01/07/16 08:20 PM
So this week ive been picking away at a project ive been wanting to do for a while now. Custom front strut brace. Its a dc sports bar for a 2g eclipse with custom mounting plates. Turned out quite well.
01/08/16 07:15 AM
looks great!!
Mn92gvr4
(Member)
01/23/16 01:50 PM
She is coming out! Time for rods and top-mount turbo.
Mn92gvr4
(Member)
01/28/16 08:53 PM
So i just pulled the pistons and rods. Was planning on just doing rods buuuuut the pistons are pitted as f#ck. So lets replace them to. I am fairly new to the bottom end of the motor. So stock comp ratio is 8.3:1 correct? Im planning on running quite a few booostes, would there be much benifit of switching to an 8.5 or 9.0?
Somehow the cylinders are still mint
jeverts
(Member +)
01/28/16 09:03 PM
Raising the compression will always get you more power. How much pressure are you planning on running? Even on 9.0 to 1 you will have no problem running 35 psi on E85.
Mn92gvr4
(Member)
01/28/16 09:17 PM
35 is right around what im looking for. I will be running a borgwarner s300sx 8375, which is capable of 45psi. And if i can reach that i will. Whats the rule of thumb? Higher boost lower c.r?
diambo4life
(Member)
01/28/16 10:41 PM
I like 8.5:1. That is already a touch higher than stock which is 7.8:1. I like the extra margin of error that lower compression gives you. You could throw a bunch of boost and timing to it and still be relatively safe. I would mic your bores for taper and concentricity bro especially with the condition of those slugs. At the bare minimum, a cylinder hone will be required when you fit new slugs in there.
Mn92gvr4
(Member)
01/29/16 06:16 AM
I was planning on running a hone through it for sure. How would i check the others? Slap the caliper in there at a few different points? Its a little concerning those only have 30k on them
jeverts
(Member +)
01/29/16 08:35 AM
The best way would be a dial bore gage. Most people are not going to have that equipment. The other way would be with telescope gages and a micrometer. Calipers are not accurate enough.
On another note. You can go 9:1 pistons with that turbo and the boost that you want to run. You just need to make sure you have good enough rods to handle that. Those 1120 low z injectors will not be able to handle that. Even if you went to stock compression pistons you will probably run out of fuel. Same with the fuel pump. Your going to need to go to a wally 400 and run -8 feed lines.
Mn92gvr4
(Member)
01/29/16 09:41 AM
I have manley turbo tuffs coming. I think im going to go with the 8:5 comp ratio just to be safe. Atleast until my tuning skillz are up to par. I know i am going to run out of fuel at some point. That stuff is a 30 min job to swap out.(inline pump). I'll cross that bridge when the time comes. Dont suppose map has a dial guage they "rent" out?
Mn92gvr4
(Member)
02/03/16 01:46 PM
Look what mr.fedex brought me today!
Mn92gvr4
(Member)
02/06/16 12:16 PM
Today i realized that i hate the monstrosity that is our fuse boxes. Other that relocating to the glovebox or something what options do we have? Is there some sort of aftermarket option/replacement?
Mn92gvr4
(Member)
02/11/16 04:55 PM
Made a little bit of progress today. Kiggly main girdle. On the arp main studs do i have to back them up half a turn before torqueing like with the head studs? Anybody know the torque specs or should i go figure out how to use google?
(A hole)
02/11/16 09:01 PM
Did you have the block checked/machined with the ARP main studs torqued and girdle in place?
Mn92gvr4
(Member)
02/12/16 06:29 AM
Studs were already in the motor. I just dropped the girdle in for fitment.
Mn92gvr4
(Member)
03/03/16 04:29 PM
Ok. So i finally got my pistons and rods. Manley turbo tuff I beams and manley pro series dished 8.5:1. On gapping the rings (top and 2nd) they say for high boost application on the gap go bore size times .008 and with the oil rings a min of .015. Anybody have any personal experience with this? Should i just go with it?
Mn92gvr4
(Member)
03/05/16 08:47 AM
Out with the old in with the new.
Mn92gvr4
(Member)
03/17/16 08:43 PM
I found some time to take care of a couple little projects ive been wanting to do.
Mounted my battery. Odessy pc680 with the odessy bracket.
Ive never been fond of our brake fluid reservoir. It will mount in the stock location, just less of an eye sore.
I came up with this using a weapon-r can i had laying around.
Mn92gvr4
(Member)
03/21/16 07:16 PM
I got the can back from the welder and was able to finish up this set-up. I am thoroughly pleased.
Mn92gvr4
(Member)
04/01/16 06:16 PM
Jm fab top-mount twin scroll
Mn92gvr4
(Member)
04/01/16 06:21 PM
I do have one small fitment issue. The front motor mount needs to come down 1/8". Has anybody ran into an issue like this before? Would it cause the engine to sit to far out of wack if i weld and redrill the holes in the bracket? Thanks in advance.
Mn92gvr4
(Member)
04/09/16 05:34 PM
The engine found its home today.
[url=http://
Mn92gvr4
(Member)
04/26/16 07:23 PM
Today i was finally able to attach an engine to my turbo lol.
Borg warner s300 s-60 8375.
jeverts
(Member +)
04/27/16 12:11 PM
A 1g BOV seems pretty small for that size of a turbo?
Mn92gvr4
(Member)
04/27/16 07:44 PM
Why is that the first thing everybody notices? I simply haven't gotten to it yet, its on the list. I put the ic pipe in there for mock-up proposes.
jeverts
(Member +)
04/28/16 12:03 PM
It sticks out like a sore thumb that is probably why. Just was wondering that is all.
Mn92gvr4
(Member)
04/28/16 12:05 PM
That it does. Probably going to order up a tial soon though. It will fit much better.
Mn92gvr4
(Member)
05/06/16 03:50 PM
She is almost ready! Wastegates shipped out today. Hoping for a first fire next weekend.
undrpressure23
(Newbie)
05/10/16 08:35 AM
So sick man!
Mn92gvr4
(Member)
02/04/17 09:54 PM
Time to bring this bitch back from the dead. 936 is fatally rusted so I just picked up 1512 from breakrrr (matt) out of Colorado. She just got dropped off by the transport today.
Meet 936 2.0
Mn92gvr4
(Member)
02/07/17 07:56 PM
Today I started prepping the bay for a shave and paint.
On an unrelated note i now have a passionate hate for the color white.
Mn92gvr4
(Member)
02/15/17 09:30 PM
Just thought I'd drop a few more photos here. I put my "special" upper radiator support on and started cleaning up all the worthless holes in engine bay.
Mn92gvr4
(Member)
02/18/17 08:57 PM
Por-15ed the engine bay today. Still have to drop the front subframe and clean that up. Then I can drop the engine in.
02/19/17 05:25 AM
hell yeah, get your protection on. car looks good.
Mn92gvr4
(Member)
02/19/17 08:53 AM
Thanks bud. She will get there slowly but surely. And por15 everything!
I'm sick of rust on my vehicles.
Mn92gvr4
(Member)
02/19/17 07:21 PM
Got a bit side tracked by a shiney Orange object today. Picked it up today for 450.
Mn92gvr4
(Member)
02/22/17 08:13 PM
Dropped the front sub-frame to clean it up and give it some fresh paint.
Also started fab work on the air box.
mooserage
(New Title)
02/22/17 08:46 PM
This makes me want to POR-15 my car so bad. I'm curious, why spray paint instead of POR-15 on the subframe?
Mn92gvr4
(Member)
02/23/17 06:35 AM
I did 2 coats of por-15 then topcoated it with chassis&rollbar paint, gave it a nice matte look. Por-15 does recommend a top coat. Something to do with uv protection.
02/23/17 06:51 AM
for underhood sunlight, you know because of the light weight see through lexan you use for a hood.
Mn92gvr4
(Member)
02/23/17 09:34 AM
Precisely. I guess it just comes down to personal preference. The engine bay will also be receiving a top coat one I'm completely done with it.
Mn92gvr4
(Member)
03/06/17 10:23 PM
So just a little progress here. I dropped the engine in for mock- up purposes.
Side note. Why do I have to run my pics thru photo editor in order to upload them?
I've been throwing around ideas for tires as well. I don't have any rims yet. Just had these laying around the garage. 265/35r18 95w. What's everybody running for width?
03/07/17 06:15 AM
What size are your photos? There is a 2mb size limit I believe. I have run into it a few times.
those tires are super wide. If you get them to fit in te fenders you may end up with the turning circle of a Dually if they will even fit.
Mn92gvr4
(Member)
03/07/17 09:38 AM
That makes sense. I checked and my photos are 3.6mb, I'll have to change a camera setting or two.
I'm just playing around with the tires right now. It would be nice to use them all around but maybe just rears and go slightly smaller up front.
03/07/17 09:44 AM
You will have to be real careful with the tire sizes if you do that, you will destroy the drive-train if the sizes are off. Need to keep the same rotating diameter at all 4 corners
Mn92gvr4
(Member)
03/07/17 12:03 PM
I know you can't run different heights, is it the same rule with width?.
03/07/17 12:41 PM
You can stagger them, but in order to run a wider tire, you have to run a lower aspect ratio. You also have to look into how the tires sit (or compress) as the lower AR will normally have a stiffer side-wall and not compress as much, so you may also have to run different tire pressures t equal out and save the drivetrain.
(A hole)
03/07/17 07:40 PM
All of the tires need to have the same rolling diameter. It will require math to ensure that condition is met.
Mn92gvr4
(Member)
03/07/17 10:36 PM
Ah, I see what your getting at now. Well it's good for thought. I will have to see what kind of clearances I can get and go from there. Probably would be easiest to go with a narrower tire. I just have these floating around the garage, it would be nice to use them.
Mn92gvr4
(Member)
03/16/17 02:19 PM
I just finished doing a fuse box relocation. Over all I am happy with the results. It was a huge headache but is well worth it. I still have to finish running my power supply cables.
Mn92gvr4
(Member)
03/24/17 07:48 PM
While browsing rockauto I came across this relocation kit. Pair it with a ffofh and it would clear up a lot of downpipe room.
Mn92gvr4
(Member)
07/13/17 05:46 PM
It's been a busy few months but I have managed to get an update for everybody.
Introducing the "new" 936
TheRedBaran3
(Newbie)
07/14/17 08:02 PM
Looks great man! My engine bay and subframe are por15. The stuff is great. Maybe one day I can get deep into a build like this
Mn92gvr4
(Member)
07/15/17 11:38 AM
Stuff is happening now. Missed being able to work on her. Brake lines and clutch lines installed. Motor and trans going in next.
Mn92gvr4
(Member)
07/29/17 12:05 PM
Generated in 0.005 seconds in which 0.002 seconds were spent on a total of 4 queries. Turbo powered.
