Vr4junkie
(writes like a tard)
02/11/12 09:53 PM
Build Thread of 385/2000
My old B13 SE-R that I sold to buy my GVR-4
Bought a Rare car and even rarer from the ORIGINAL OWNER!! Completely stock
All maintenance paper work
385/2000 after a wash and wax that didn't do much
Didn't even get the chance to change the oil gatta love the VR-4
Well finally getting some progress heres a few pics for mean while
Block Decked and Bored
2g NPR pistons 0.030 over
20 year old transmission after a quick power wash
Sand Blasted the Tranny not sure what color I should paint it
LIV4PSI
(dyslexic 1051 )
02/12/12 12:29 AM
Re: Build Thread of 385/2000
Just using stock replacement parts basically? I can't wait to go through all of my drivetrain.
Vr4junkie
02/13/12 12:36 AM
its going to be some what stock 2g pistons Acl Main and rod Bearing ARP Hardware
LIV4PSI
(dyslexic 1051 )
02/13/12 01:57 AM
That's a good setup, and all most really need. What about the drivetrain? Did you just clean it up while the engine was out? I can't stand when people put filthy parts back onto the car after they have been removed.
Vr4junkie
02/13/12 12:15 PM
Yea perrty much since its out might as well clean it plus I found out we have a sand blaster at work and I can use it when ever I'm on my time off. For the drivetrain im looking into Jacks maybe replace the sncryos get there double 2nd gear still not sure and a 4 bolt rear end when I could find one at the yards.
Vr4junkie
02/17/12 10:18 PM
Just got These in the mail
Nippon Full Gasket set
Nippon MLS head gasket
OEM Timing Belt
ARP Head Main and Rod Bolts and Prothane Inserts
ACL Bearings I was going to use till I saw there were made in CHINA REALLY ACL!!!
So I ended up ordering there Race Series Bearings Made In Australia more like it
Vr4junkie
04/01/12 01:44 PM
cleaned up all the grease and grim now time for some paint
Paint could of been better dam wind
Vr4junkie
04/08/12 05:43 PM
Spay painted the Tranny Wrinkle black
Vr4junkie
06/01/12 04:40 AM
Some of the new toys.
Polished Standard size crank.
Porting and polishing the head still not close to done.
Vr4junkie
06/01/12 04:51 AM
Flywheel I got from a member.
Glow shift Boost and Oil press gauges
Summer time is coming so time to cover her up.
se7enine
(Member +)
06/01/12 06:33 PM
Builds looking good, I miss being in Bako. I'm glad that I'm at 4300 ft above elevation though, it's about 10 deg. cooler. I do hate how far I have to travel to get to L.A. and the Ventura, it's quite the drive but a fun one. Good luck with the build
Vr4junkie
06/02/12 04:19 PM
Thanks little by little but its getting there ...yea weather out here isn't that great as you already know freaking hot all the time.
Vr4junkie
08/01/12 05:03 AM
Opening up the tranny
Glad to find out I have this tranny click might go for there evo 1st and double syncro 2nd and evo 5th not 100% sure yet
Vr4junkie
11/23/12 09:53 PM
One of my new toys 1/2 50-250ft/tq neighbour sold it to me for 20 big ones guess the company he works for is getting all new tools. It was recalibrate last year might be time for another calibration.
Vr4junkie
02/15/13 06:02 PM
Finally picked up my Evo 9 suspension got it from a guy I met at the Buttonwillow race track just ganna have to sand it down take the surface rust out and give it a coat of paint.
(295hp 35r BR4)
02/15/13 07:25 PM
Very clean, I like the black painted parts.
Vr4junkie
02/15/13 11:08 PM
Thanks I just sprayed some paint over the rust spots for meanwhile.
Now I just gotta figure if I I want to keep stock springs or get some after market springs any suggestions?
**DONOTDELETE**
(Unregistered)
02/18/13 10:14 PM
Seeing this thread for the first time. I bought 390/2000 which also happens to be Nile Black from it's original owner! Granted it didn't come with all the maintenance records like yours, but still pretty crazy that 2 so closely numbered stayed with the original owners so long! Good work so far!
Vr4junkie
05/10/13 01:43 PM
Master bushing set
Drive shaft carrier bushings
3M under coat
(Banthony )
05/10/13 02:19 PM
If you haven't already done it, I would recommend you replace the 2 outer exhaust manifold studs with larger ones (2g style) while you've got it all apart.
Vr4junkie
05/10/13 02:27 PM
Well im ordering new studs from ssstuds.com I see 7 M8 Studs and 2 M10 studs is this what your taking about?
Vr4junkie
05/14/13 12:31 PM
Some stainless steel valves
So I bit the bullet and gave the XTD unsprung clutch a try.
The G Ride finally JSB
Vr4junkie
05/14/13 02:28 PM
Just got these in today
(295hp 35r BR4)
05/14/13 05:00 PM
XTD is the brand of that clutch?
Vr4junkie
05/14/13 06:34 PM
Yup.
Vr4junkie
05/14/13 11:20 PM
Here's a little bit of todays progress front and rear sub frame out these are going to be the before and after pics.
Im even ganna give the lines a paint job
bobdole
(Old member with new to me VR4 and starting over. Respect your elders kids)
05/15/13 10:22 PM
Looks good so far. Keep up the good work.
Vr4junkie
05/16/13 11:46 AM
thanks I underestimated the under carriage I've gone through about 8 bottles of oven cleaner and 2 bottles of degreaser so far I got all the heavy stuff out the way.
05/16/13 11:50 AM
haha thats always my favorite part about buying an old car, the first real cleaning of crap off everything.
the car looks great, keep up the good work.
Vr4junkie
05/16/13 12:32 PM
Thanks yea some of this stuff was baked up on there pretty bad but I'm ganna work on it this week finishing cleaning and prepping so by Tuesday I should spray it down.
Vr4junkie
05/19/13 03:13 PM
Some paint for the suspension and engine bay will be going with some kind of candy pearl something from these guys click .
CutlassJim
(poop load of room)
05/22/13 09:16 AM
I quite jealous of how everything from under the car looks almost new. Mine was a mess when I took it all out. Damn Californians!
(295hp 35r BR4)
05/23/13 09:21 AM
all those pics say 2007 on them, but you said this is current progress?
G
(JDM Unit)
05/23/13 10:14 AM
Time date stamp in camera is probably set incorrectly.
Vr4junkie
05/23/13 09:21 PM
Yea CutlassJim it wasnt too bad just alot of dirt but other than that no rust or anything bad.
And yes the photos are current I just never setup the date since it resets every time I start the dam thing.
Vr4junkie
05/24/13 01:52 AM
Just got this little guy in the mail today HY35
Vr4junkie
06/03/13 03:20 AM
Some Boostx bushings
5lb Tumbler works awesome defiantly recommend one of these.
1hr in the tumbler with some purple power not bad.
Under coat finally done.
KiNgMaRtY
(Member +++)
06/12/13 03:48 PM
Nice progress!
(295hp 35r BR4)
06/12/13 04:28 PM
Looking pretty nice under there.
CutlassJim
(poop load of room)
06/12/13 06:08 PM
Did you have a thread going over what undercoating you used? I can't seem to find it now.
Vr4junkie
06/12/13 08:12 PM
Thanks guys little by little its getting done now I need to by a soda blaster or media blaster.
CutlassJim heres the link >> click
Vr4junkie
11/06/13 12:25 AM
Here's a little update... some new parts that have been laying around now that im currently unemployed Ill be working on the car a lot more but tomorrow I should have the suspension parts back from soda blasting and ready to paint.
Heres a few pics for the meantime.
New Tie Rods
New Wheel bearings all around
New Ball Joints
New Wheel Bearing seals
New boots
Vr4junkie
11/06/13 03:59 PM
Couple parts back from soda blasting should start painting by tomorrow.
G
(JDM Unit)
11/06/13 05:37 PM
Looking good.
ApexHunter
(Extreme Indoor Cyclist)
11/07/13 10:17 AM
Just found this thread. Making some nice progress!
LIV4PSI
(dyslexic 1051 )
11/07/13 11:01 AM
Great job so far. I have been taking on this same project on 1501, so I understand just how much work is involved. Hopefully you didn't have to fight as much rust as I did
(Banthony )
11/07/13 04:10 PM
Quoting Vr4junkie:
And what or who exactly is it you are defying by recommending one of these?
Vr4junkie
11/09/13 07:29 PM
Rust wasn't really an issue I think the only thing that really had any rust was the rotors
The tumbler is a nice tool to have around I mostly use it to clean bolts and small parts leaves the threads nice and clean and there cheap if you use there 25% off coupon.
So here's a little of today's progress.
pot
(It's a twee shaker----choot him choot him)
11/09/13 09:09 PM
Quoting mitsuturbo:
Quoting Vr4junkie:
I was slightly confused myself. Of caution though, while the tumbler is great for small pieces like the water neck, caliber bracket, etc, be cautious with the bolts as the medium will remove the factory zinc/cadmium coating. This will cause your bolts (while looking sharp in the short-term) to wind up acquiring surface rust.
Vr4junkie
03/06/14 01:21 PM
Sprayed a last coat of anti corrosion paint
Almost assembled missing a few bolts
Jay Racing rear toe elimiinator and rear upper adjustable control arms
Evo suspension on Swift springs.
G
(JDM Unit)
03/06/14 05:00 PM
What's the part number for the sankei ends?
Vr4junkie
03/06/14 05:28 PM
This is it G got them off Amazon.
G
(JDM Unit)
03/06/14 07:05 PM
Sweet, so sankei # se-7261. You know these are for a space wagon right? Edit, I see the new # mb564991 works for galants.
Vr4junkie
04/27/14 05:06 PM
A little update front and rear bolted up might finally touch touch the floor again.
Vr4junkie
05/01/14 02:13 PM
She's finally off the jack stands .
05/01/14 03:38 PM
nice, thats a great feeling dropping the car on the ground.
Vr4junkie
05/01/14 10:56 PM
Yes it was all that hard work finally paid off but yea it did felt great knowing its got fresh new bearing and literally all new bushings . But it's still has a lot to go but its getting there little by little.
Vr4junkie
05/08/14 05:43 PM
Getting the engine bay ready for some paint.
Vr4junkie
09/09/14 07:23 PM
Just got done painting the engine bay it's a metallic grey can't really tell by the crappy phone pictures not the best painting by far but might keep it for a while.
Mister1161
(Newbie)
10/02/14 08:16 AM
Great progress. The engine bay color is flawless.
Vr4junkie
11/10/14 04:37 PM
So this is about the only rust I found on the entire vehicle so far
All this dirt was stuck under the fender.
Sanded it down luckly it was only minor surface rust.
Sprayed some anti-corrosion paint on it.
Did the oil galley mod.
2G head minor port and polish ,3 angle valve job,Stainless Steel valves,oil port mod ,diamond cut resurface ,new valve stems,stock valve springs for now.
6bolt rods with 2g pistons & ARP rods with ACL Race Series Bearings
ARP main studs ACL Race Series Bearings,newer standard size crank shaft.
Copper sprayed the MLS head gasket also head has ARP Studs.
Block and head assembled.
Generated in 0.006 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
