bmod530
(Junior Member)
07/17/10 06:41 AM
Wiseco HD Pistons HIT the oil squirters...
After instating the rotating assembly, I noticed that the pistons hit the squirters and deflect the tube. I will post a pic up soon. Anyone have an idea whats up here? Im going to call Wiesco in a couple hours to question. Looks like EVO squirter's could do the trick to fix it though. This problem is with the 1400HD pistons 0.020 over.
bmod530
(Junior Member)
07/17/10 07:23 AM
Re: Wiseco HD Pistons dangerously close to squirters...
Check it out...
bmod530
(Junior Member)
07/17/10 07:49 AM
Bigger
bmod530
(Junior Member)
07/17/10 08:07 AM
I didnt realize it was Saturday and there not "open"
Barnes
(Firechicken)
07/17/10 10:24 AM
One thousandth of a millimeter? Or one thousandth of an inch? I know in internally rotating parts you don't need a huge amount of clearance, but I'm pretty sure you need more than 0.001". What part of the squirter do they get close to? The body? The little squirter tube itself?
bmod530
(Junior Member)
07/17/10 10:27 AM
i was not trying to give a specific measurement, just purely stating that it is VERY close. It almost hits the end of the tube, where the oil is to be "squirting" from. Its flush with the bottom of the piston.
bmod530
(Junior Member)
07/17/10 11:20 AM
***UPDATE The squirter actually hits the piston! After taking a closer look I was awestruck. Is there anyway I can clearance it by cutting down the oil squirter? Or should I just block em off?
onesickcrx
(Brother of the Year)
07/17/10 11:41 AM
Street car?
bmod530
(Junior Member)
07/17/10 11:44 AM
yes....so I would like to keep them.
jepherz
(Too Clean)
07/17/10 12:30 PM
Can you bend the squirters? I thought I've heard of people doing that before. Maybe they didn't intend people using the squirters?
4thStroke
(Spence knows tools)
07/17/10 12:32 PM
My motor has Mahle pistons. When the motor was assembled, they were supposed to make sure the pistons wouldn't hit the squirters. When I dropped the pan, I found 2 broken squirters in the pan. I didn't feel like dealing with it so I just removed whatever was left in the pan and sealed up back up. I contemplated blocking them off, but again, I didn't feel like wrenching in such a tight spot.
I believe Smitty had to clearance his Mahles, too.
They can be bent around, just be careful not to bend them too much and break them.
GVR-4
(Creative Name Huh?)
07/17/10 03:24 PM
Just add an extra aluminum crush washer or a steel one sandwiched between two aluminum ones.
bmod530
(Junior Member)
07/17/10 04:50 PM
Quoting jepherz:
I feel like this would cause a weak point in the tube, and would be a *Stress riser.
Quoting 4thStroke:
Thats unfortunate, and exactly what I DON'T want to happen! Again i'm not sure I feel %100 comfortable bending the material (Steel or brass????) into plastic deformation.
Quoting GVR-4:
I like this idea because I have extra (used) washers. 1 or 2 extra washers and maybe a little off of the tip of the squirter might just do the trick.
bmod530
(Junior Member)
07/17/10 05:41 PM
NOTE: 2 Extra washers below the squirter will cause an interference with the crank and tube, and still does not have enough clearance to the pistons.
bmod530
(Junior Member)
07/18/10 01:21 AM
just cut a bit off of the tip and looks a little better now. supposedly a warning note from Wiseco says that the piston skirt will contact the oil squirter's. you need to re-adjust them and allow a minimum of .030 clearance between the skirt and the oil squirter.
07/18/10 12:27 PM
When I built my engine I had one or two wiseco pistons that hit the squirters. I just bent the squirter a little to clear the piston. Have not had a problem in over 12k miles.
fivestardsm
("Savior of the damned and dis-owned")
07/18/10 12:36 PM
Quoting bmod530:
Bigger
Your squirter is not positioned correctly.
It is supost to be angled to the center of the piston a little bit more. It should just clear the side a little so that it sprays the "cup" of the piston. Just CAREFULLY bend it so it clears the side of the piston web.
bmod530
(Junior Member)
07/19/10 05:37 AM
Just installed the new bent jets and it is good to go. Steve, i'm going to be driving up to Big Rapids in a month, your gonna have to check out #88/2000. I sold 1847 out here in California. Thanks everyone for the advice/info
fivestardsm
07/19/10 11:05 AM
Sweet. Give me a call when your on your way.
231-250-5972
GVR-4
07/19/10 08:34 PM
Here's a photo of one of my bone-stock oil squirters.
rexwagon1909
(impatient cutter)
05/15/13 11:29 AM
To add to this thread we were building my motor the other night using Wiseco 10:5 HD pistons and they do hit the oil squirters. We are taking about 2mm off the tips and re drilling tip
05/15/13 11:36 AM
Just bend them out of the way.......
Way easier and faster.
rexwagon1909
(impatient cutter)
05/15/13 11:38 AM
My builder doesnt want to risk bending one and end up possibly weakening them. Since they are brazed/sodered on dont want to chance it
05/15/13 01:37 PM
Re: Wiseco HD Pistons HIT the oil squirters...
They bend easy. I've bent several sets, no issues. You only need to move them a little bit.
Generated in 0.005 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
