Diego
(Mad Hatter Suite Touche Debackle Guage filled by Justin)
08/29/11 11:06 PM
New turbo setup..
So I sold my E316G to a member here and I sent it out and got it back in the mail, so I was able to get a side by side shot...
FP20G vs E316G
It is externally gated and I have an Ebay 38mm V-band Wastegate for it but dont plan on running it for safety factor that I WANT to know the spring pressure..
Does anyone have something cheap for me to buy and maybe a recirc or atmospheric dump for this...
biglady112
(or what)
09/01/11 11:39 PM
Re: New turbo setup..
You can hook it up to a compressor to see when it opens. Or just order your desired Tial spring. They usually fit and work just fine.
Diego
09/02/11 05:12 PM
I will try that.
spooling92vr4
(Yeah Toast! * Now with JELLY!!!)
09/04/11 07:59 PM
I think I have a spring or two laying around, it could take a few days for me to get out to my shop to grab it, Im not sure I remember what the rate is... (I remember putting 2 in for like 18psi) so that must have been the og spring... anyway if you pay for shipping its yours.
Diego
09/06/11 03:42 PM
As I expected, the 20G housing is huge and hits the waterpipe, anyone have any advice on how much of a dent i need to give the waterpipe clearance from the housing or is there another route?
Diego
Scott Y
(mighty skunk hunter)
09/06/11 07:00 PM
You do have to dent the waterpipe if you clock the compressor housing to point the outlet forward so you can use the stock i/c route over the manifold.
I don't have an exact measurement, I used the trial method of bending and installing until I had the clearances I wanted.
Diego
09/06/11 07:52 PM
Its down facing. Any of you CO people able to help a brother out and make way up here to offer advice or a helping swing as I don't have crap for tools atm.
Diego
DynastyLCD
(Dissapointing Member)
09/08/11 06:17 PM
Quoting Scott Y:
that explains why i didnt have to dent my water pipe. my FPgreen fits perfectly but then again it goes downwards.
i was able to slightly clock it up, and use a piece of stock 2g I/C piping (just for the 90 bend) and it fits a 1g short route FMIC kit without issue. the engine mount was the only obstacle.
Ian M
(waiting for the bus)
09/09/11 04:29 PM
Quoting Diego:
Diego
You need as much as it takes to get it to bolt on.
Seriously,It's been years ago now,but I remember having to dent mine slighty (my 20g is clocked up) also. I laid a socket against the pipe and hit it to make a smooth dimple that looked almost stock.
Diego
09/11/11 11:09 PM
Its in. Anyone have a link for new studs. Mine are just a bit rusty and I would like new hardware.
Generated in 0.005 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
