DSMTurbo2
(Freeze plugs hate me)
04/01/10 12:52 PM
FS: 91 GVR4 Traverse City, Michigan $4500
1991 Mitsubishi Galant VR4
Limited Edition number: 1189/2000
Belize Green / Black Leather Interior
5-Speed Manual, Non Sunroof
157k Miles and driving
Has Original Key, Original Dash Plaque, Original Key FOB! Title is free and clear and in hand
Drivetrain and Suspension:
 4-Bolt Limited Slip Rear Differential (stronger, LSD)
 4 Wheel steering properly removed
 ABS Properly and Completely Removed
 5 Lug Wheel Conversion (5x114.3)
 GoodRidge Smoked Look, Stainless Steel Brake Lines on all corners
 Motul RBF600 Brake Fluid
 Fidanza 8lb Lightweight Flywheel
 ACT 2600lb Clutch with Street Disc (Will be putting in (next week)
 Energy Suspension Urethane Bushing Front and Rear Engine Mounts
 Energy Suspension Urethane Bushing Control Arm Kit
 Solid Brass Shifter Bushings
 Stainless Braided Clutch Line
 Eibach Pro-Kit Front Sprigs (have rears off car)
 16” Motegi Wheels
 225/50 R16 Kumho Ecsta Supra Tires
 Front Strut Tower Brace/Bar
 TEL Shorter Shifter with Leather Shift Boot
Engine / Management and Fuel:
 6 Bolt bottom end REBUILT with less than 5000 miles on it.
 .020 over
 ACL Bearings Everywhere, All Mitsubishi OEM Gaskets
 ARP Head Studs
 ARP Main Studs
 ARP Rod Bolts
 2g Pistons with 8.5:1 Compression Ratio
 Mobil 1 full synthetic (changed 5 times already on this rebuild)
 Big 16G-Td05 Turbo (great shape, no abnormal shaft play)
 Custom Intake Mounted Behind Headlight
 12” K&N Open Element Filter
 Evo III Exhaust Manifold (ported/Polished)
 Evo III o2 Housing (ported/Polished)
 3” Bushur Racing Mandrel Bent Stainless Steel Full Exhaust
 Indy Race Core xXxXx Front Mounted Intercooler with 2.5” Inlet/Outlet Piping.
 RC 550cc/min Fuel Injectors
 NGK Blue spark Plug Wires (less than 500 miles)
 NGK BPR7ES Spark Plugs
 Walbro 255lph Fuel Pump
 Dejon Tools Dual Stage Manual Boost controller.
 MegaSquirt MS2 Version 3 Full Fuel and Spark Control Stand Alone ECU, with complete custom harness (no cut and splice garbage)
 Zeitronix ZT-2 Wideband Oxygen Sensor with Display and Integrated EGT and Boost Pressure Sensors.
 Air conditioning Deleted
 Cruise Control Properly Deleted ( Includes non-cruise throttle cable)
Other:
 Factory Mitsubishi / Thule Roof Rack (very rare item)
 Battery Located To Trunk With Proper Fusing and 0 AWG Speaker Power Wires and Fully Enclosed Summit Racing Battery Box With Vent.
 Grex Shift knob
 Black/Red Grant Steering Wheel
 Viper / Directed 5600 2-Way Alarm (warns of alarm triggering on your remote)
 JVC MP3 Stereo Deck
 Amplifier for stock stereo
 Can include (4) 1gb Talon Wheels with mounted 195/55 R16 Bridgestone Blizzak WS-50 Snow Tires
 Have working sunroof assembly I can include as well as many extras.
Does have typical hood rust on leading edge and a spot on the A-Piller. It has a stupid Grant steering wheel as well.. Sorry. Body has is original paint and aside from the aforementioned, is in great shape! There are normal dings and rock chips, also a few areas on the bumpers where you can see it was swiped in parking lots (don't notice until you are within 10 feet). Interior is in great shape, the vinyl is separating around the radio a bit, and below the dash plaque has a bit of cracking. Carpet is a bit dirty, but not terrible, no crazy stains or rips/tears. The plastic hinge on the door between the rear seat and the trunk is broken but still there. The trunk is bare, I am contemplating cleaning it up and maybe adding some textured paint (similar to a rhino lining). All glass is original except for the recently replaced front windshield. Does have some drive train noise... Nothing abnormal for a galant, just needs the drive shaft rebuilt with new carrier bearings. the exhaust flex section is starting to leak a bit, and it does drip a bit of oil. I believe the leak is around the turbo return line (go figure). Trying to be open and honest and describe all the problems, if there is anything I missed I will try to keep this updated.
I am selling my pride and joy for the last 4 years because it sounds like I am getting a real job that is going to require me to travel. This has been my dd and college car, and has really been great to me. I planned to keep it forever but I wont have anywhere to keep it. I would like to see this go to someone who is familiar with these cars and really shares the pride, I have been involved in DSM's for over a decade and truely cherrish the VR4s.
Best way to get ahold of me right now is by PM or email ([email protected]) I will be quite busy for the next week or so, so please be patient. I am not at all interested in entertaining low ball offers or dealing with tire kickers, don't waste my time and I will not waste yours.
thank you.
Erik
More Photo's to come!
This is the rust dust in the trunk. It isn't even surface rust... it really is rust dust???
DSMTurbo2
04/12/10 10:26 PM
Re: FS: 91 GVR4 Traverse City, Michigan $5500
No more interest?
DSMTurbo2
04/24/10 11:25 PM
Clutch is in... she is ready to go. little sad.
DSMTurbo2
04/27/10 12:49 PM
Re: FS: 91 GVR4 Traverse City, Michigan $5000
Bump for added pictures.
DSMTurbo2
05/05/10 08:23 AM
Might consider some trades.
**DONOTDELETE**
(Unregistered)
05/05/10 01:56 PM
WTT for GVR4
Price Range: Up to $7,000
Range: Any
Contact: Zach Hainline
[email protected], or PM, or call 417-860-9142
Details:
Made the mistake of selling off #327/2000 4 years ago and I madly miss it. I need another. My car is activly for sale, but would always consider a trade. Not looking for a turd unit, but rather a pretty clean one. Nothing ragged out. Mildly to highly modded. Could always take some cash back if you only have a GVR4 worth $4000, yet its the right one. Prefer Black or White. If your trade has any mechanical issues, or a rough interior.... forget about it. Leaks fluids or smokes.... forget it. I know they are going on 20 years old but I am looking for one that has been very well maintained and can be driven anywhere on a 100 degree day with icy a/c. My car is immaculate and has been babied. SUPER clean inside and out!!
1999 Infiniti Q45
134K
Black on Black
20" Chrome Rims
Immaculate Condition Inside and out
Exterior 9/10
Interior 9.5/10
Drivetrain 9.5/10
Rims 8/10
Tires 9/10
DSMTurbo2
05/05/10 09:09 PM
Hello Zach, quite the ride but not quite my taste. I don't think you should have much trouble getting rid of that Infinity. PS I have removed my A/C... I live in Michigan
Erik
centurion882
(Junior Member)
05/07/10 08:41 PM
Re: FS: 91 GVR4 Traverse City, Michigan $4500
Can you call me about your car??? 989 370 5624 thanks dan
centurion882
(Junior Member)
05/14/10 08:51 PM
Erik, tring to contact you about your car, call me at 989 370 5624 thanks dan
DSMTurbo2
05/31/10 10:40 AM
Sale Pending
bmod530
(Junior Member)
06/01/10 05:40 AM
Hey Erik, what are you looking to buy next?
DSMTurbo2
06/01/10 10:29 AM
I have a diverse list. I think I an fairly set on awd, quick (not fast), has a good deal of space. I am probably picking up an A4 Avant with quattro and the 2.8 with a 5spd.
bmod530
(Junior Member)
06/02/10 05:31 AM
^^^^^^^ Sounds like you should keep your VR4!!! A4's are always nice, I had my brothers 97 A4 quattro for a month up in BR and loved it. Def. extra space in the wagon though. GLWS
DSMTurbo2
06/03/10 07:52 AM
Believe me, it is very hard for me to get rid of this car. I want something i can have a little fun with. I don't like to beat on the galant, too much time in it. I want a car that is just a car that I can have a bit of fun with.
The car is back up for sale.
I had 2 or 3 emails on my Outlook right before it crashed. If someone on here has emailed me recently and not gotten a response, I apologize but could you please email me again.
Erik
centurion882
(Junior Member)
06/03/10 09:26 PM
Erik, is car still for sale?????????? Call me I am still intrested 989 370 5624 Thanks dan
centurion882
(Junior Member)
06/27/10 07:41 AM
Erik, have been trying to contact you, would like to look at your car, call me 989-370-5624 Thanks Dan
DSMTurbo2
06/27/10 09:53 AM
Dan I apologize. Are you available today?
Erik
centurion882
(Junior Member)
06/27/10 07:48 PM
Yes, I was in TC, call me I want to look at car 989- 370-5624 Thanks DAN
centurion882
(Junior Member)
06/29/10 09:26 PM
Erik, leave your phone and I will call you, I still would like to look at car!!! Thanks DAN
centurion882
(Junior Member)
07/08/10 08:35 PM
Eryou ik, this is the last tme I will try to contact you, I have sent you many e-mail and you failed to call me, if i do not hear from you in 48 hours, I will buy smething else!!!!!!!!!!! 989- 370-5624 DAN
DSMTurbo2
07/09/10 07:34 AM
Dan I have called you on 2 different occasions, my apologize that I have not tried you more often. I have just recently started a new job, and have been absolutely swamped. In your emails you say nothing different than you say here. Call me? Do you have any specific questions I can answer? I would be happy to try you again late tonight, but working 3 jobs 7 days a week does not leave me a ton of free time. Again my sincerest apologies.
Erik
centurion882
(Junior Member)
07/11/10 07:18 PM
Erik, do you have a phone number?????????? Have a few ????'s about car still intrested in looking at your car!!!! 989 370 5624 Thanks DAN
DSMTurbo2
07/12/10 06:06 PM
Quoting DSMTurbo2:
Erik
Can you just email your questions? It seems a bit easier?
centurion882
(Junior Member)
07/13/10 07:54 PM
Erik, no special ????'s I just want to look at your car; to buy!!!! 989-370-5624 Thanks DAN
**DONOTDELETE**
(Unregistered)
07/28/10 04:58 PM
Man hard guy to get ahold of I want also I live like a mile and a 1/2 from you Steve lohners budy I think you now him he's got 2 vr4s swantechs old one
DSMTurbo2
07/29/10 08:47 AM
I don't think I am that difficult to get a hold of. But I am working allot right now. So I just have weird hours when I am available. I do know Steve. Where do you live HTATALON?
**DONOTDELETE**
(Unregistered)
07/30/10 07:09 AM
On Reynolds a mile or so from cedar run I've got 1ga a lil built up I'm thinking of getting rid of if I sell this or if you still have it buy the first of the year Id pick it up from you I got brents old galant from him and never should of got did of it
centurion882
(Junior Member)
07/31/10 09:57 AM
Still intrested in looking at vr-4's if you have one for sale or parts call 989 370 5624 dan
Generated in 0.004 seconds in which 0.001 seconds were spent on a total of 4 queries. Turbo powered.
