(Old Balls)
07/23/12 07:14 PM
FS: 92 Galant VR4 425/1000 Davenport, IA $13000.00 SOLD
I have owned this car since Dec of 2003. I started with it as a bone stock car with 113,000 miles at a bank repo lot. I have spent 9 years bringing this car to this point. It is a 9.8(maybe better) out of 10 both inside and out. I am extremely anal and nothing has been left to chance. I daily drove it for 5 years before getting really serious about the restoration. In the last 4 years, it has not seen snow/ice and only got wet to wash it and getting caught in the rain at MOD one year.
I would not hesitate to drive this anywhere. As you can see from the info below. It is running a very safe "street setup" tune of 361whp at only 18psi on Shell 93 octane gas.
I am asking $13,000 firm. That is $2000 less than appraisal value and that was before the interior restoration/dynomat work, EVO III tranny, drive shaft, engine bay, radiator, piping, battery, and ECMlink V3 w/SD setup dyno tuned work.
This car is insured for $20,000 at Hagerty Insurance (costs $400 a year). It is worth every penny.
If you have any questions, email me at [email protected] or PM me here with your phone number and I will call you.
The only "bad" thing, drips about 3 drops a month from the oil pan gasket.
This is one of the best 5 examples in the USA. Below is the exact "Members Showcase" thread with current pictures and examples of what has been done extra.
Body:
New paint by Tom Lindle
Factory Summit White
New emblems
New chrome
White handles
Rustoleum oil based flat black undercoating
Complete engine bay restoration
Looks like a new car
Mods:
Motor Fully built by Class One Inc
2.3L stroker with cryoed and MicroBlue coated bottom end
Stainless Steel O-ringed deck
Eagle rods
JE .40 pistons
ARP hardware throughout
3G lifters
BC 280 cams
Sleeper stock intake mani that has been cut, knifedged, and re-welded
Throttlebodys.com rebuilt 65MM TB
Stock oil pan with -10 drain fittings
Custom 10"x10" oil cooler w/8" fan and -an10 braided lines
PLX wideband O2 with gauge inside cabin
Mitsu timing parts
Rebuilt ported head
Supertech springs
Profain motor mounts
1G style aftermarket Radiator w/twin 12" fans custom setup for 160 degree operation
Fuel
RC750 injectors
255 Walbro pump rewired with 10Ga wiring
SARD AFPR with Marshall mechanical 100psi gauge underhood
Tranny/Driveline
Headdynamics rebuilt tranny and T-case
EVO III spec tranny (double syncros on 1,2,3,&4, close ratio 3/4, the works)
ACT Chromemoly flywheel
Clutchnet sprung 6 puck w/3X PP
Mitsubishi Diaqueen
Brass shifter bushings
TEL shifter
New master and slave cylinders
4 Bolt LSD rear
Red Line Heavy Shock proof in T-case and rear
Complete Drive shaft rebuild using all OEM parts
Forced induction
PTE SC6152RSP A/R .70 ball bearing
FP Race exhaust manifold
JGS external wastegate
Custom stainless steel down pipe (Head Dynamics one-off work of art)
FMIC and piping from Extreme Turbo Systems
Forge BOV (vented to atm)
4 Bar Speed Density
GM Intake Air Temp sensor
4" aircleaner setup with a cold air box
Lower Shores Performance MBC
3" turboback exhaust w/o cat
Brakes/Tires/Suspension
Ceramic pads on all 4 corners
New rotors - 5 lug Stop-Tech cross-drilled/slotted all around
Yingling 215/45/17 ZR Ultra High Performance rubber
Enkie 2 piece OEM rims (won at MOD 08)
Full ABS delete
New flexible brake lines
H&R Galant VR4 specific springs
KYB GR2 struts in rear
Monroe Sensa-trac struts in front
Whiteline front swaybar
Whiteline rear swaybar
Whiteline rear strut tower brace
Cusco front strut tower brace
5 lug hubs
All new OEM wheel bearing/seals/lug nuts/lug studs
Electronics
PLX WBO2
Marshall Oil Pressure gauge
Marshall Fuel Pressure gauge
Marshall Boost/Vac gauge
Marshall Volt gauge
ECU capped and socketed
ECMLink full V3 w/speed density setup
Relocated full size battery to firewall
There is plenty more but this list is long enough.
Dyno graph on 6/14/2011
Video of a second gear pull on 6/14/2011
Pictures taken in July 2009 pics:
Pictures taken in March 2012:
Pictures taken in July of 2011. New engine bay paint, speed density setup, EVO III transmission, new intake piping, radiatior setup, etc...
Pics of some of the custom work done by Chris Beran and other custom work.
Gauges change color with dash lights
Curtis rails (before new undercoating)
Flip4G63
(Den Mother)
07/23/12 11:05 PM
Re: FS: 92 Galant VR4 425/1000 Davenport, IA $13000.00
i think i just creamed a little.....
glws! worth every penny imo
(Hard Snarker)
07/24/12 12:31 AM
Reason for sale?
91_427
(Member)
07/24/12 12:34 PM
I will trade you my soul and first born for your car. PM if interested.
(Old Balls)
07/24/12 02:49 PM
Quoting turbowop:
Reason for sale?
Need new project, anything more this car needs is going to be a "personal choice" and not a need. I am ready to start looking for something else and I don't have the garage space to keep this and another "labor of love".
rheckert
(I Love Wagons)
07/24/12 03:20 PM
Build a bigger garage. Problem solved.
Next
GLWS Terry!
**DONOTDELETE**
(Unregistered)
07/25/12 12:13 AM
I hope this car goes to someone as loving as you have been. That's a great looking galant. Just for clarification, there is no radio/audio in there?
jcgalntvr4-244
(WAY 2 many)
07/25/12 01:04 AM
fucken sellouts...............
Puertorican22
(Junior Member)
07/25/12 08:37 AM
What a beautiful VR4 good luck with the sale.
(Old Balls)
07/25/12 10:58 AM
Quoting PearsVR4:
There is no radio, but there is a 4 channel amp with IR remote and an Ipod cable (actually has 3 stereo RCA inputs). Connected to the factory wiring for speakers.
Not the best clarity but is decent and works well.
getboosted
(Member)
07/25/12 06:43 PM
Does it still have working A/C? Very nice and GLWS!
_______________________-
(Old Balls)
07/25/12 08:37 PM
No AC. It worked fine before I removed it.
Could be re-installed but the radiator and oil cooler would have to be modified.
All electrical for it is still intact.
bustedsm
(trying to feel really special)
08/01/12 02:51 PM
I want this so bad, but I highly doubt you'd be up for a straight up trade with my Typhoon.
(Old Balls)
08/01/12 05:30 PM
No sir. No trades.
Sorry.
bustedsm
08/01/12 08:28 PM
Damn, A- for effort I s'pose!
**DONOTDELETE**
(Unregistered)
08/19/12 01:43 PM
could you txt me a phone number to call about the car, 607-339-1166 -karl
Ben
(Member)
10/02/12 08:22 PM
I know you said no trades, but it doesn't hurt to ask. A 1960 mini cooper?
gvr4ever
(Forever Member)
10/02/12 09:03 PM
It looks like new old stock. Good luck with the sale.
(Old Balls)
10/02/12 11:13 PM
Quoting Ben:
Sorry, no.
However, post up yor Mini in Anything Goes. I would love to see it.
Ben
(Member)
10/02/12 11:37 PM
It belongs to a guy I work with. He just traded a deuce and a half RV for it. haha
blacksheep
(Baraqsheep)
10/04/12 06:31 PM
This is a great example of a well-restored gvr4. Really wished it had AC a headunit in conventional location, but thats just how would I personally done different!
(Old Balls)
10/04/12 08:31 PM
I hear you KC. AC is not happening, but I may redo the center console.
Thanks for the compliment, it means a lot coming from you.
(295hp 35r BR4)
11/25/12 06:09 PM
I really hope this goes to someone who will take care of it. gLWS
NateCrisman
(Fisheye Hoodpins)
11/25/12 09:59 PM
Wow, this is a special car. Good luck with finding a buyer, the effort into this car deserves someone who will continue it.
**DONOTDELETE**
(Unregistered)
01/29/13 10:00 AM
GORGEOUS CAR.
Srr
(Newbie)
01/29/13 04:42 PM
Nice car man good luck...
(Old Balls)
02/02/13 04:44 PM
sold
jcgalntvr4-244
(WAY 2 many)
02/02/13 05:24 PM
Sad to see you sell your car Terry . It was good having you as a member here its sad to see people that give to the community leave over things that could have been handled in different ways .....
Anyway sad to see you go brother.
Cheers
JC
(Space Blanket from NASA plumbed into the attic)
02/02/13 05:48 PM
No Doubt the new owner got a nice one, miss having you around.
VR6Eater
(ShiftBoots?)
02/03/13 11:16 PM
Guess who bought it?
Dealing with Terry for this car has been one of the best experiences I have ever had buying a vehicle. He made my family feel at home while we talked shop and showed me everything he had laying around that was GVR4 related. I wouldn't hesitate to do business with him again.
(Hard Snarker)
02/03/13 11:45 PM
Well it didn't take you long to get back in the game after rejoining the site.
VR6Eater
(ShiftBoots?)
02/03/13 11:52 PM
Next time I'm looking at a job at Walla Walla State Penitentiary I will let you know. Saw your car a couple time over the last ten years, but couldn't keep up in the rentals. I'm in deep now, got back a couple hours ago from Decatur, picked that one up for the wife.
(Hard Snarker)
02/03/13 11:55 PM
Wait, what? You've actually been out here and saw my car on the road? But nobody here believes that I drive it...
VR6Eater
(ShiftBoots?)
02/04/13 12:01 AM
4 years ago Yakima had us come in and epoxy their showers for the county jail and I saw you. Gotta know what your looking for.
(Hard Snarker)
02/04/13 12:37 AM
Nowai? You should have PM'd me. We could have met up and had beers! Next time...
3rdstrikedsm
(Now mandatory for Wendy's Chili to come with cheese)
02/04/13 08:31 PM
Quoting jcgalntvr4-244:
Cheers
JC
+1 Stay in touch!
pot
(It's a twee shaker----choot him choot him)
02/04/13 09:23 PM
Very, very sad but happy for you at the same time.
(Turn Right Racing)
02/04/13 09:53 PM
Quoting VR6Eater:
Wow, talk about jumping in with both feet.
Hondakiller
(Member)
02/10/13 02:32 PM
Re: FS: 92 Galant VR4 425/1000 Davenport, IA $13000.00 SOLD
Now that a car to buy. Beutiful.
Generated in 0.005 seconds in which 0.002 seconds were spent on a total of 4 queries. Turbo powered.
