381gvr4
(used by hotroders)
12/31/11 03:25 PM
SOLD:1991 VR4, $GG's Spent!7k on build,30rDBB,Teins,EVO8 ecu, $7900 CT
I'm located in RI and the car is in CT. It's my toy car. She makes the 300mile roundtrip RI/CT/RI all the time. I have a poop load invested in this car and now that I'm back to a career, its time to step up my game. I have owned this car for 4yrs and done tons of work documented in my build thread.
I have a folder FILLED with receipts(90% of items) totalling $12000. This does not include the car, the time and things like tuning.
I AM IN NO RUSH TO SELL THIS!!! I get CONSTANT local offers but when its time to exchange money, no one can make good on their deal! I'm asking $8500 PRICE DROP TO $7900 which is a steal for what you are getting. I am 100% confident this car can be driven ANYWHERE in the conutry without a hiccup! I also will entertain offers with some parts removed to reduce cost....
She does have some small body items that if the car is kept, will be addressed in the spring.
-2 small rust spots around windshield quarter and dime size
-Rear quarter infront of the p/s taillight has a smal scrap/dent
Owner: Russell Richards
Bought:11/07
Year:1991
Number:381/2000
Current Mileage:100,400 and counting..... as of rt now.
Mileage on build:7,220
1/4 time: TBD
WHP: 430awhp
BUILD THREAD click
Engine: click
Built bottom end click
-Wiesco 9.0:1 .20 over pistons
-Eagle rods
-Polished unground crank
-B/S eliminated
-Balanced to 10K
-Fluidamper balancer
Built Head
-Mildly ported head by myself ext click int click
-Manley springs/retainers/keepers
-Ferrea valves with 3-angle
-BC272's
-3g lifters
-Mitsu MLS headgasket
-Hondata intake gasket($.99 on epay)
-ARP Mains, headstuds, crank bolt, exhaust studs, rod bolts, turbo bolts
-New Mitsu oil pump/cover, mitsu waterpump, new mitsu tensioner, idle pulleys, new waterpump/oil pump cover/tensionor hardware click
-90' OFH, -8an lines, B&M 11x6 cooler
-New oilpan, knock sensor, ALL GASKETS/SEALS
-Drilled and filled motor mounts
-NGK spark plugs
-NGK spark plug wires
-New oem 1g dipstick with modified tube with spring click
Turbo:
-Garrett GT3076R in EVOIII exhaust housing click
-35mm internal wastgate
-Stainless braided oil feed from head
-Stock oil return
-Custom -6AN ss water feed line and return
Intake:
-Rebuilt VR4 throttle body
-2g t/b elbow
-2g MAF
-4" FP recirc intake pipe
-K&N filter
-Custom short route Aluminum 2.5" intercooler piping.
-Spearco intercooler with custom endtanks (core size - 24 x 9 x 4)
-Oil catchcan
-Crushed oem NIB BOV
Exhaust:
-2g ported exhaust manifold
-2g manifold heat shield and modified o2 shield
-ARP Stainless exhaust manifold studs
-2.5" to 3" mild steel downpipe
-3" mild steel bent catback with Borla single tip muffler click
-Catco 3" high flow cat
-EvoIII ported o2 housing
-RRE/Indy Race Cores Aluminum Radiator GVR4 specific
Electronics:
-Evo8 ecu
-Black Top CAS
-Greddy electronic Boost, EGT and memory/warning oil pressure
-NIB Greddy Profec B spec (original from 95)
-Dual stage turbo timer
-NEW Bosch 90amp alternator(original receipt with lifetime warranty)
Fuel system:
-Rewired Supra TT fuel pump
-Aeromotive AFPR
-SS -6an lines from filter to rail, from rail to afpr and from fpr to return.
-750cc FIC injectors
Drivetrain:
-Rebuilt TRE trans dual syncs in 2-3, filter, new forks, bearings, seals, rails
-Redline MT-90
-New front axles
-2g shift fork and throwout bearing upgrade
-ACT 2600
-ACT Flywheel
-Stainless braided clutch line
-DSM 5-lug conversion with all new bearing, seals and dust shields
-4bolt LSD rear end w/ AWS click
-Restored rear subframe. Complete sandblast and Eastwood products click
-Restored lines, rear rack, rear pump, dist block
-Rebuilt driveshaft with FM u-joints and new carrier
Suspension:
-Tein HR coilovers with front camber/pillow and rear pillow mounts
-Ingalls adjustable rear upper control arms
-DSM front and rear adjustable strut tower bars
-New rear sway bar end
Brakes:
-Front- 94+ 3kgt 4 pot calipers with 12.65" dual vented rotors, stock pads
-TunerNation(GW) caliper brackets
-Rear - Stock calipers on DSM 5 lug rotor
-Complete ABS removed and swapped for 1g non abs lines and proportioning valve
-SS brake lines
Wheels/tires:
- 17" EVO 9 Enkei Wheels
- 235/40/17 Azenis
Interior:
-EVO MR SE gas, clutch and brake pedals with WRX dead pedal
-1989 Light weight underdash with pocket
-Starion OPEN headrests in black leather click
-Sony Explod Black out CD player
-Double DIN carbon fiber plate for radio, Greddy oil pressure, boost and egt gauges
-"MITSU" 1g leather steering wheel
-2g DSM shift knob
-Leather shift boot
-1g DSM EXTREME PSI short shifter
-Paint removed from cluster needles, repainted red on tach and temp gauge click
-Moroso NHRA legal sealed battery box click
-Custom TURBOFLANAGAN numbered floor mats click
Exterior:
-JDM vented RS hood
-Eterna grill
-MMC VR4 trunk badges(removed Galant, DOHC and MITSUBISHI emblems) click
-OEM Mudflaps click
-JDM Eterna Grill
-93 crystal headlights
-Amber corners with signal and parking light
-Tinted tail lights
-Complete Rubberized undercoating to entire underside including under skitrs, doglegs and wheel wells click click
Again, I'm in no rush but would like to payoff a CC before I dive back into the car payment world!
Thanks, Russ
12/31/11 03:57 PM
Re: FEELER:1991 VR4 100k $G's INVESTED!7k on build,30rDBB,Teins,EVO8 ecu TUNED. $8.5
wow gorgeous car and awesome price. i wish i had an extra 8g's lying around so i could buy this....
**DONOTDELETE**
(Unregistered)
01/01/12 05:20 AM
This looks like an awesome car; such a shame it's on the other side of the country. Free bump.
381gvr4
(used by hotroders)
01/01/12 04:28 PM
sale pending....
381gvr4
(used by hotroders)
01/05/12 06:43 PM
Re: SALE PENDING:1991 VR4 100k $G's INVESTED!7k on build,30rDBB,Teins,EVO8 ecu TUNED
Back up due to deadbeat without funds! BUMP
turbojew
(Small Tattoo of 97 Chrysler Concorde on Left Buttock)
01/05/12 11:46 PM
Re: FEELER:1991 VR4 100k $G's INVESTED!7k on build,30rDBB,Teins,EVO8 ecu TUNED $8500
Would love to trade my 89 starion for it lol
381gvr4
(used by hotroders)
01/06/12 11:36 AM
No thank you. Looking to trade cash for 381....
codeofdastreets
(Junior Member)
01/06/12 10:17 PM
car has ac?
381gvr4
(used by hotroders)
01/07/12 12:38 AM
A/c removed but have parts....
Rausch
(Rock Star Status)
01/07/12 02:19 PM
Need that location in the title.
CutlassJim
(poop load of room)
01/07/12 04:19 PM
Quoting akdriverjd:
Quoting 381gvr4:
I am 100% confident this car can be driven ANYWHERE in the country without a hiccup!
Thanks, Russ
Take him up on the challenge Sally!
381gvr4
(used by hotroders)
01/25/12 08:29 PM
Price drop to $7900.... No trades
381gvr4
(used by hotroders)
03/07/12 02:56 PM
ttt
quato
(Member)
03/12/12 12:18 AM
I would love to take this car off your hands! However, I'm not due to come back to the states until this fall. If it's still for sale then, remember me, lol!
turbophein
(Member ++)
03/15/12 12:57 PM
tempting! your right around the corner too!
381gvr4
(used by hotroders)
03/15/12 02:34 PM
^^^^ No deposit yet! I've had ALOT of interest with the weather change.
I had our dent guy at our dealership do $350(retail ) worth of work yesterday. He messaged out the D/S rear door crease and a couple of little door dings!
Spring time BUMP!
ScreaminE
(Just don't like an idiot)
03/15/12 02:50 PM
I swear I'll never own another DSM or GVR4, but your car is so tempting. You seem like the type of person you really want to buy a car from.
turbojew
03/15/12 03:13 PM
WISH I could buy this. Amazing Car and Build, just double my budget. haha
381gvr4
(used by hotroders)
03/15/12 05:11 PM
^^^ Double your budget and about 1/2 of what I spent! lol Gotta love cars!
Quoting ScreaminE:
Thanks for the kind words. I AM a neurotic, nut case! I just want something with a warranty so I can throw the keys to one of my techs and say " FIX THIS!" Used GT500 or new Coyote.....
turbophein
(Member ++)
03/15/12 05:39 PM
i here you... new car warranty is the way to go. I know i am going to get flamed for this but i was considering the new turbo kia optima or the hyundai genesis for a toy car, with warranty of course. so much easier to just fill it up and do proper maintenance. they don't look half bad nowadays either.
03/15/12 08:06 PM
^^ im all about that new kia. i was thinking the same thing... except the hybrid version... there cheap and get crazy awesome gas.
jmorri15
(Member)
03/15/12 11:05 PM
the new genesis coupe is coming out too, 274hp 4b11 powered 34mpg and the aftermarket is beginning to make parts for it. ive driven the optima and sonata both are great cars but the new genesis is so sexy
381gvr4
(used by hotroders)
03/20/12 02:48 PM
Looking to move on and getting more motivated to sell. Already have loan for new Stang but want this gone to go as downpayment!!!!!
381gvr4
(used by hotroders)
03/26/12 09:53 AM
sale pending
381gvr4
(used by hotroders)
03/27/12 03:42 PM
Re: SALE PENDING:1991 VR4, $GG's Spent!7k on build,30rDBB,Teins,EVO8 ecu, $7900 CT
SOLD.... I hope the new owner loves her as much as I did!
turbojew
03/27/12 09:34 PM
Congrats how much did it go for?
381gvr4
(used by hotroders)
03/28/12 09:24 AM
Just enough not to part it.....
dustyduff
(Member +)
03/28/12 09:44 AM
Hopefully you didn't get lowballed too much. Your car looked like it was priced very well for all the work you had into it (and how clean it was).
381gvr4
(used by hotroders)
03/28/12 11:52 AM
^^^I'm ok with it. I dont know if the new owner wants me to disclose the amount, but we are both happy. I'm kind of heart broken as I am down to only my truck as a driver. New toy in the wings but as of now I have only the Camaro!
turbophein
(Member ++)
11/28/14 10:35 AM
who bought this and is it still in the area?
Generated in 0.008 seconds in which 0.006 seconds were spent on a total of 4 queries. Turbo powered.
