**DONOTDELETE**
(Unregistered)
01/03/06 09:29 AM
Jared Hansens #218/2000
Owner: Jared Hansen
Message Board Name: 91glant
Year: 1991
Number: 218/2000
Best 1/4 mile time: 12.94 @ 103
Dyno Numbers: 519WHP / 435WTQ
Comment: DD/Weekend Warrior
Power:
Comp 101200 Cams
Mitsu 4 layer HG
ARP Headstuds
Megasquirt V3 Standalone EMS
Bar and plate Core with Custom Piping
Tial Knockoff BOV
Freshly Rebuilt Head with new seals and 3 angle valvejob
3 inch mandrel bent stainless exhaust and down pipe
SBR GT14BB Turbo
Stainless Oil and Coolant lines for turbo
Logic performance Stainless Tubular Exhast Manifold
Custom Tubular 02 Housing
Tial 40mm Wastegate with o2 Dump
1000CC injectors
Walbro 255hp fuel pump
Dentsport stainless steel fuel pump housing
Stainless fuel line with 6AN fittings Tank to Filter
Stainless Filter to rail line
Stainless Fuel Return line
Aeromotive FPR
Stainless steel exhaust manifold studs
TurboXS MBC
Balance shafts removed
Forced Performance Intake Pipe
DriveTrain:
Switchable transfercase FWD/AWD
4bolt LSDrearend conversion
4WS removed
TRE rebuilt trans
Quaiffe front LSD
Stainless clutch line
Some type of short shifter with leather shift boot
Steel shifter bushings
ACT 2600
Suspension/Handling:
Hot Bits Coilovers
Noltec camber/caster plates
Whiteline sway bars front and rear
Whiteline rear strut bar, front was stolen
Urethane bushings
ABS removed
Stainless brake lines
PS removed
GOLD Rota Subzero Wheels
Toyo Proxy4 Tires
Audio:
Eclipse Headunit
Aftermarket Speakers ALL around
Alpine Type R Sub 12"
Obcon Amplifier
8 Gauge Wiring Kit
**DONOTDELETE**
(Unregistered)
01/04/06 10:58 AM
Re: Jared Hansens #218/2000
Generated in 0.003 seconds in which 0.002 seconds were spent on a total of 4 queries. Turbo powered.
