pot
(It's a twee shaker----choot him choot him)
05/23/16 06:09 AM
FS: '91 Gvr4 Partout (560/2000) NB *Updated June 2nd
FS is nearly everything from a 1991 Galant vr4 badge number 560/2000. All parts prices include PayPal fees & Shipping Costs for CONUS based transactions. First come first served.
I accept all payments via PayPal to: [email protected] I will update this thread with new parts as I remove them from the vehicle. You may also contact me via mobile no (910) 689-6150
Engine
Engine Mount Bolt *Driver Side $3.00
Autometer Oil Pressure Gauge $15.00
Resistor Pack $35.00
Throttle Cable Guide $3.00
Body
Front Driverside Turn Signal Lamp $15.00
Horn Set $8.00
Front Driver Dogleg $35.00
Front Door Molding $50.00 each
Rear Door Molding $50.00 each
Hood Bumper Set $5.00
Hood Latch $8.00
Hood Release Cable $8.00
Hood Cable Guide $3.00
Hood Alarm $3.00
Wiper Arm Set *Driver Wiper Foil is not included $30.00
Hood Cushions $3.00
Hood Hinge Set $15.00
Air Inlet (Passenger Side ) $8.00
Cowl Trim $8.00
Relay Set *Engine Bay $12.00
Timer Unit Defogger $8.00
Alternator Relay $8.00
Door Lock Relay $8.00
Front Window Regulator $25.00 each
Rear Window Regulator $25.00 each *Rear Driver side sold
Door Ajar Sensor Set $15.00 or $3.00 each
Door Wiring $15.00 each
Door Striker $3.00 each
Outside Door Handle Base $7.00 each
Outside Door Handle Cover $3.00
Front Door Lock Actuator & Latch Assembly $20.00 per door
Rear Door Lock Actuator & Latch Assembly $20.00 per door
Fuel Lid $15.00
Fuel Lid Hook $3.00
Driver Quarter Glass $40.00
Passenger Quarter Glass $40.00
Fuel Pump Wiring Cover Set $8.00
Driver Tail Light $40.00
Trunk Wiring, Part no MB543015 $30.00
Rear Passenger Tow Hook $20.00
Interior
Passenger Dash Speaker Cover * Driver Sold $12.00 each
Chassis Control Module $25.00
Foot Rest $8.00
Gas Pedal $20.00
Brake Pedal $20.00
Clutch Pedal $60.00
Brake Light Switch $8.00
Clevis Pin $1.00
Turn Signal/Cruise Control Stalk $40.00
Driver Side Mirror Trim Set $8.00
Front Skuff Plate $5.00 each
Rear Skuff Plate $5.00 each
Visor Set $15.00 each
Door Card Retainer $1.00 each
Interior Door Handle Backing Set $3.00 each
Driver Window Switch $40.00
Interior Door Pull Handle 8.00 each
HVAC Control Trim $25.00
Parking Brake Adjuster $10.00
Radio Antenna Cable $8.00
Buzzer $3.00
Shifter Base & Assembly $40.00
Center Console Side Trim $12.00 each
Doorcard Light Set $3.00 each or $15.00 for all
Center Console Trim $12.00
Glove Box Light $5.00
Retractor Assembly $30.00
Control Unit Auto Seat (MB 617345) $20.00
Armrest $40.00
Rearview Mirror $15.00
Window Switch Set $5.00 each
Dome Light (Non-Sunroof) $20.00
Emergency Brake $30.00
Hood Release $3.00
ETACS (MB852353) $40.00
Passenger Door Speaker Cover $12.00
Front Lap Belts $15.00 each
Rear Shoulder Belt $15.00 each
Rear Speaker Cover $12.00
Trunk Trim $8.00
Trunk Dome Light $3.00
Trunk Trim Striker $20.00
HVAC
Cooling Unit $60.00
Blower Motor $50.00
HVAC Control $20.00
Heater Unit *Does not include Heater Core $60.00
Auto Comp Controller (MB276780) $12.00
HVAC Adjuster Tab Set $2.00
Harness, A/C Thermostat part no MB 276781 $15.00
Drivetrain
Clutch Master Cylinder $15.00
Clutch Line Bracket $5.00
Flange Yoke to Differential Hardware Set $2.00
Brakes
Front Driver Brake Line $15.00
Rear Brake Line $8.00 each
Brake Fluid Reservoir $15.00
Low Brake Fluid Sensor $8.00
Non-ABS Brake Lines $40.00 *Missing Passenger Side
ABS G Sensor, Front $20.00
ABS G-Sensor, Rear $20.00
Driverside Emergency Brake Cable $20.00
Steering & Suspension
Front 5 Lug Hubs $65.00 each
Front Driver Control Arm $30.00
Front Passenger Control Arm $30.00
Front Control Arm Clamp $15.00 each
Front Swaybar Mount Set $10.00
Endlink Set $5.00
Rear Crossmember Bracket Set $15.00
5 Lug Wheet Nut Set $25.00
Rear Stock Springs $30.00 each
Rear Strut Mounts $15.00 each
Lower Control Arms $17.00 each
Rear Swaybar Bracket Set $5.00
Rear Upper Control Arms $17.00 each
ty_miggy
(Newbie)
07/02/16 09:40 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB
Is the rear windshield trim available? If so, how much and what condition?
Snook1345
(Junior Member)
07/06/16 03:47 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated 4 July
Interested in 5 lug swap and 4 bolt read end and glove box
(295hp 35r BR4)
07/06/16 10:38 PM
I need a very tiny part. It's a floor plug that is on the floor board behind the passenger seat carpet. It's about the size of quarter.
galant412
(Junior Member)
08/27/16 10:09 AM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated August 27
Wish I was closer I would come get that hood and the.Top part of the radiator core support.
jduke0308
(Junior Member)
08/29/16 02:59 PM
Just sent paypal for the under dash cover and 2 of your door lock tabs.
jknadia
(Newbie)
09/20/16 03:50 AM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated September 17
Are you parting out the DOHC badge on the trunk?
diambo4life
(Member)
09/20/16 09:02 AM
Exhaust hangers. I need one but can get them all.
bigandbad
(Junior Member)
09/27/16 10:51 AM
Do you have a set of the rear hub splash shields in a good condition?
bigandbad
(Junior Member)
09/27/16 01:20 PM
Thx... I tried at some Mitsu-dealers, here and in the US. Part is discontinued. JNZ even hasn't it in their system...
(Turn Right Racing)
09/27/16 04:44 PM
I may have a pair.
turbohf
(anyone even read this?)
09/28/16 10:15 PM
vents are mine. thanks!
Toago
(Newbie)
12/04/16 08:17 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated November 14
please let me know if you could ship a working rear window defrost switch up to Canada, ideally through Express shipping haha!
Ben
(Member)
12/11/16 01:41 PM
Are you willing to ship a door?
(Banthony )
01/24/17 03:03 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated January 12
I'm looking for a stock rear differential. I don't really even need the internals. Just the case with the hole for the 4ws pump.
dave
(Newbie)
02/06/17 11:52 AM
do you still have the MPI relay if so i need one.
brodiedehass
(Newbie)
05/19/17 03:51 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated 12 May
I am seeking front and rear windshield exterior metal trims and the plastic trim on the bottom side of the sunroof attached to the glass.
Ian M
(waiting for the bus)
07/11/17 12:01 AM
I'm looking for (8) of the white clips that attach the roof trim strips to the body.
Ian M
07/14/17 11:14 PM
Awesome,thanks!
Ian M
07/14/17 11:24 PM
(I'm not sure how I missed your response,but I appreciate it!)
HadesOmega
(Newbie)
08/29/17 12:05 AM
Would you happen to have:
Fuel filler hose (hose that connects from next to tank)
Rear Caliper guide pin boots
sway endlink bushings
Muggus
(Junior Member)
11/20/17 06:43 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated November 11
I sent you a pm about some parts but now i cant seem to find whether or not it actually sent. Let me know, thanks
bobdole
(Old member with new to me VR4 and starting over. Respect your elders kids)
11/21/17 08:46 AM
Fog light switch harness pig tail?
pot
12/02/17 08:44 AM
Quoting Muggus:
Please PM again, I did not receive it.
pot
12/02/17 08:48 AM
Quoting bobdole:
I do not have one Charles.
Roehre009
(Newbie)
12/06/17 01:18 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated December 2
It wonít let me send a pm, can you message me so I can ask if pets are available?
Duncan
(Newbie)
01/23/18 08:01 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated January 6
How much for all the badges off the rear. Just picked up a 91 and its missing them all.
pot
01/23/18 08:39 PM
Iím afraid I only have what is in the pictures.
Duncan
(Newbie)
01/23/18 10:39 PM
I take it the shell is gone? To bad will have to keep an eye open I guess.
drifter148
(Member)
02/03/18 08:06 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated January 27
Are the front fenders available? If so how much for them Including shipping to 46055
pot
02/04/18 07:31 AM
I only have available what is pictured. Thank you for looking.
cruzreymart08
(Newbie)
04/06/18 08:37 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated March 29
Still available?
-Visor Set (Pair)
-Front Speaker Cover (Pair)
-Rear Speaker Cover (Pair)
TheWolf
(Newbie)
04/13/18 10:56 AM
I am looking for 2 rear deck speaker covers, rubber hood bumper set, hood cushions, front seatbelt latchs(part with the red release button) and a power mirror switch(the one that controls the mirror and folds them in. My interior is dark gray and I am in Chicago area zip 60107. Thanks in advance
pot
04/19/18 04:10 PM
Quoting cruzreymart08:
Still available?
-Visor Set (Pair)
PM sent
cruzreymart08
(Newbie)
05/03/18 08:55 PM
i didnt received any pm sir
newbie
(Newbie)
07/23/18 02:34 AM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated April 20th
do you still have the passenger side rear door molding?
pot
08/02/18 12:09 PM
Yes it is still available. I will be PMing you now.
newbie
(Newbie)
08/03/18 06:19 PM
i need front and rear passenger side door moulding, do you still have it?
Deboelduro1
(Newbie)
09/26/18 01:13 AM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated August 23rd
Do u have the drivers side a pillar trim ? Also windshield washer reservoir with lines and motor
Deboelduro1
(Newbie)
09/26/18 01:16 AM
Also need a front window regulator
Deboelduro1
(Newbie)
09/26/18 01:52 AM
Also blower motor Iím interested in
pot
09/26/18 09:56 AM
Quoting newbie:
PM sent
JamesFoster
(Infamous BMX Master)
10/06/18 01:15 AM
Any body parts still available?
Deboelduro1
(Newbie)
02/13/19 02:43 AM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated February 11th
What parts do u have left
pot
02/13/19 12:36 PM
Everything you see pictured in this thread and the 3 other threads that I have.
RebuiltVR4
(Newbie)
03/07/19 03:44 PM
Hey man I just bought Miguels #520 White VR-4... are you still parting things out? will you cut metal? if so... how much for a passenger side rear 1/4 panel section?
pot
03/08/19 06:17 AM
Congratulations on your purchase. Unfortunately, I donít have any metal available but if you happen to need anything else please donít hesitate to ask.
adie0986
(Newbie)
05/21/19 10:53 PM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated April 6
Rear emblem still have sir?
pot
06/02/19 08:11 AM
Re: FS: '91 Gvr4 Partout (560/2000) NB *Updated June 2nd
Plenty of stock parts are still available.
Generated in 0.006 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
